Home | Air Conditioners | Goodman hvac unit not...
Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
Goodman hvac unit not working no power
By jpage01 on May 17, 2009
goodman hvac unit not working no power. touchscreen thermostat not reacting to touch unless pressed very hard. swapped thermostat faceplate with downstairs unit and it works fine. No power for a/c or furnace. Fusebox shows all power is on and emergency switch is on. What could be problem?
Comments:
May 26, 2009
- GMS9 unit 3amp fuse blew but after replacing fuse on board with a 5amp still does not work properly. At first a/c unit began working (light came on) so I put door back on then stopped working again. Gave a quick flash of light and went out. Fuse looks fine? Is this a contact problem? Unit only 3 yrs old, no apparent wiring issues
May 29, 2009
- Sorry to confuse but my post meant to say that t-stat faceplate was tried on lower level hvac and worked fine but won't work on problem unit upstairs. Neither faceplate seems to fix prob on upstairs unit. Seems that when 3amp fuse blows the t-stat touch screen does not react unless pushed forcefully. Called t-stat company and they suggested disconnecting 'blue' wire from t-stat (it is optional anyway) but no change. I think fuse has blown again on c-board. Does this sound like problem with system board?
May 29, 2009
- HVAC guy just left, had a bad transformer that needs to be replaced. The old one looks brand new but he tested it and even swapped it with the one downstairs to confirm it was bad. I jus hope that there was nothing else between the t-stat and circuit board that blew the tranny.
I'm still open to comments on this thread
Sponsored Links
Clarification Request
Posted by jumptrout51 on May 17, 2009
By your own troubleshooting it seems you have a bad thermostat.
Solution #1
posted on May 17, 2009
Not Helpful)
jvangel1
Rank: Wiz
Rating: 82%, 54 votes
is it oil if so firomatic above the furnace in the 4x4 box could be bad that is a safety
Comments:
May 26, 2009
- I am sorry i sent the wrong answer to you i was answering another question dont know how i ended up on you request appreciate if you could respond back with inapprpiate thank you
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
anglersrv984
Rank: Apprentice
Rating: 75%, 2 votes
is your breaker a double pole or single pole breaker to the indoor unit
Was this helpful?
Yes
No
Solution #3
posted on May 26, 2009
Not Rated)
jumptrout51
Rank: Guru
Rating: 89%, 963 votes
As I said, bad t-stat.
When you switched covers it worked correctly. The t-stat sends a signal through the fuse then to the components you are calling for.
The original t-stat blew the fuse and is hard to push.
Replace your t-stat and solve your problem.
Comments:
May 29, 2009
- Remove the output wires on the control board. Turn the system on.
Replace one wire at time until the fuse blows. That will be your bad component.
Was this helpful?
Yes
No
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
frigidare gallery 30-inch freestanding electric range model:lgef3033kb
Answer
I found a new ap500pf samsung 49600 btu split air floor standing unit for sale by private seller. I... (More)
Answer
I have a unit with no panel to read trouble codes,led light blinks three times,please help. P.S how... (More)
Answer
My fujita 2.5 AC is flashing orange light when i turn it on, also green power light is flashing.Unit... (More)
Answer
We have a newer (new this summer) a/c and furnace and just in the past few days the heat kicks on at... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
