Question about Facebook Social Network
Can't access 'simple view' on Waplog .. - Facebook Social Network
How view a private instagram
If you want to look any private Instagram account, the only way is to have its password and the password can be retrieved by hacking the Instagram account.
I would like to suggest you one easiest way for hacking any of the Instagram accounts. You can use one simple user-friendly web designed app that can be accessed free of cost from this site.
This hacking tool is a superior app which is safe and doesn't require any knowledge regarding software designing and coding to operate.
May 26, 2014 | Computers & Internet
Cannot log onto wifi due to lack of password
Looks like you are trying to access a wireless router that is secured but you don't have a password. If the router is yours, it's a simple matter to go into the router setup and view or change the wireless password. I suspect, though, you are trying to access someone else's network. In that case, you need to contact the person who manages that network and get their password if they'll let you use it.
Sep 15, 2011 | Sylvania G-Netbook
Sideview mirror has broke from the base
Side view mirrors are relatively simple to replace. Sometimes it requires the removal of the complete door trim to gain access to the mounting nuts and any wiring it may have. Other times there is a triangle piece in the corner of the door window opening that can be removed by itself and allows access to the hardware and wiring connectors. Check local junkyards for a used mirror, you may even find one in the right color. Good luck.
Oct 25, 2009 | 1998 Pontiac Grand Prix
Unable to network
Are they running Windows XP? If so enable file sharing...
  1. Open My Computer from the Start Menu or Windows XP Desktop. A new My Computer window will appear.
  2. Open the Tools menu and choose the "Folder Options..." option from this menu. A new Folder Options window will appear.
  3. Click on the View tab and locate the "Use Simple File Sharing (Recommended)" checkbox in the list of Advanced Settings.
  4. To enable Simple File Sharing, ensure this checkbox is checked. To disable Simple File Sharing, ensure this checkbox is not checked. Click inside the checkbox to alternately enable and disable the option.
  5. Click OK to close the Folder Options window. The settings for Simple File Sharing are now updated; no computer reboot is required.
Jul 07, 2009 | Netopia Computers & Internet
I put a hard disk as a slave in another computer but i can not access the administrator's section. when i click it says access denied.
yes
because it is password protected.
So cant access it.
but if u set as master it and login int that operating system then u can acess it.
Jun 06, 2009 | Microsoft Windows XP Professional
PLz help to get access back for my external hard disk
iskh iskh...very pity man...simple problem...just used yor house key...just simple as that...
Feb 18, 2009 | Western Digital External USB 2.0 80 GB...
Loading music
What are you using to load music. If you have access to Windows Media Player 11 it is very simple.
First open WMP11, make sure your player is connected to the computer with the USB cable. At the top of WMP11 click Sync
the player will sync with WMP11, drag and drop music and click sync, very simple. I have a Sansa View and it is very simple, This basically works with most MP3 players.
Feb 25, 2008 | SanDisk Sansa e200 MP3 Player
The hard disk in drive D: is not accessible
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Feb 18, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Local Disk(D:) is not accessible Access is denied
This occurs when the drive was taken from a PC where someone made the drive un-shareable.
The fix in XP:
1. Turn off Simple File Sharing, via Explorer, Tools, Folder Options, View, (NOT) use Simple File Sharing.
2. Now when you right click the drive letter for the drive on the new PC you will see a Security tab (made invisible by Simple File Sharing).
3. On the Security Tab, add yourself or any user, and grant Full Permission.
4. Now you can Explore the drive like any other.
Sep 20, 2007 | Computers & Internet
Facebook Social Network Logo
26 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
