Question about Packard Bell Computers & Internet
Turn on keyboard backlights on packard bell ms 2384
5 Suggested Answers
  • 43 Answers
SOURCE: i want to download packard
I was able to find and dl some from here, not sure if its all you need though:
http://drp.su/drivers/notebooks/?v=Packard%20Bell&m=EasyNote%20TJ75&id=880&l=en
Posted on Mar 26, 2011
  • 69 Answers
SOURCE: how do i turn the keyboard light on a packard bell
Try pressing the FN key + space bar at the same time
Posted on Feb 25, 2011
priyabrat
  • 123 Answers
SOURCE: Monitor not coming on - Packard Bell Easynote R4650
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the memory modules
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Tips:
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
Posted on Jan 26, 2008
SOURCE: front usb connections
I finally found a solution, on a dead page in google cache only:
http://www.pcclub.com/forum/messageview.cfm?catid=27%26threadid=16567
The solution was posted by JontyBonkers.
The pins go like this:
1 2 3 4 5
_ 6 7 _ 8
1 = ground
2 = ground
3 = D1-
4 = ground
5 = D1+
6 = D2-
7 = D2+
8 = +5V
It seems that the case for those Packard-Bells had a small circuit board that divided the 5V line to both sockets.
D- are usually white, D+ - green, 5V - red, ground - black
Posted on Oct 17, 2008
How i unlock my keyboard. lts packard bell easynote TE11 BZ
Hello
Does the whole keyboard not work or only some keys?
Try the following shut down the computer , disconnect the power cable and remove the battery from underneath then press power button for about 20 seconds then reconnect the battery and the mains power and switch on the laptop again.
Did you spill any liquid on the keyboard?
Jan 23, 2015 | Packard Bell Computers & Internet
Packard Bell MIT-RHEA-S keyboard compatibility
Depends on your country code. The letters and symbols may be in the wrong place.
Apr 23, 2014 | Packard Bell Computers & Internet
Dark screen when switched on
Try to adjust the screen brightness using your keyboard. If the brightness is at maximum, then you need to replace your screen because its backlight is dying.
Feb 14, 2014 | Packard Bell Computers & Internet
Wireless switch
Probably in BIOS to enable it.
In Windows to configure and activate it.
Jan 25, 2014 | Packard Bell Computers & Internet
I buy PC packard bell easynote_TS11HR-032FR and the touchpad does not work, when i use my pc for the first time.
Check this:
Many laptops with touchpads have a switch or a keyboard combo that will disable the touchpad. Look to see if there is a little button you can push located near the touchpad. Alternately, there is normally a Fn-special function key combination you can use. You press the Fn key and also the special function key that has a little symbol on it that looks like a touchpad. That can turn the touchpad on or off.
Aug 05, 2011 | Packard Bell 160240 Mouse
I am unable to use the hot keys on a Packard Bell keyboard (SK-2300H) installed on a generic PC running Vista. The PC sees the keyboard as a standard PS/2 keyboard. Some of the buttons are active. e.g the...
Your Packard-Bell keyboard was designed to work specificaly with your PB system. The old computer came (probably pre-installed) with software and drivers that map the extra keys to functions like e-mail, calculator, volume control etc. It may be possible to make the keyboard work like it did on your old system by locating and installing the Packard Bell keyboard driver and software. Go to the PB website and select UK-Irish support location. From there go to support section and follow the automated support by filling in info such as model number etc. No guarantee it will work but worth a try.
Oct 29, 2009 | Computers & Internet
Fn key is constantly on
i just solved this problem today on my packard bell easy note all you have to do is hold the FN key and press NUMLK and then it should work
Dec 20, 2008 | Compaq Keyboard
Packard bell easynote keyboard not working
my keyobard won't work on my packard bell laptop
Nov 23, 2008 | Packard Bell Easy One Silver 2101 Notebook
Non working keys on laptop
You should just need to replace the keyboard.
However finding a keyboard for a packard bell in the US can be hard. That brand hasnt been sold here in years.
If you are in europe it should be less of a problem though.
Made sure to get the exact model of the laptop to get the right keyboard.
Dec 20, 2007 | Packard Bell Easy One Silver 2101 Notebook
Computers & Internet Logo
319 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
