Question about Brother MFC 210C All-In-One InkJet Printer
Missing dot in all colors
I have a mfc 215c printer. i made a test print for quality and noticed that there were missing dots in all colors. I have do cleaning several times. the problem still exists.
Is my print head partially clogged? I was able to remove the print head with the ribbon and tubes still attached. Can i soak the bottom of the print head in hot water to remove the clog as i usually did with my HP print catridge whenever it get clogged.
Is it correct that if ever i use generic ink it should be dye ink and not pigmented ink. Will any dye ink cause the printer head to clog.
Is there maximum no of cleaning that can be done?
  • Brother Master
  • 1,113 Answers
Yes your print head is clogged,
Ive tried a few times to refurb these particular heads with very poor results, we change them under warranty but not worth while otherwise,(150aus$) 90% of print quality faults I see I can put down to inferior ink being used threw mechanisms. There is also a power purge in service mode that pumps 1/3 of each ink cartridge threw machine and dumps it but it fails to repair missing dots most times too.
 Ive also seen people with nothing but the best ink used get long life out of machine, In my eyes it is cut and dry with recycle products there is a cost in the savings,
Inks have many different thickness, stability's and flow charactistics more than just pigment or dye being the issues causing problems blocking microscopic little holes.
Yes there is a limit to cleaning cycles it is called the waste ink counter, it stops machines function eventully before overfilling of the waste ink pads occur, I usally see the print head dead before this occurs otherwise it is a  very cheap new waste box replacement and waste counter reset im not sure of life in pages they count it in dots produced
Posted on Oct 17, 2007
  • 832 Answers
Jay,
close to the facts:
never(!!!!) clean a brother printhead by soaking it into a solution what so ever it contains!
The printhead is a piezo one and totally diffrent from hp or canon bubblejet which heats the ink to print while the brother (and epson) ones have a bi-metal insides which "fires" ink onto paper when needed. The outward cleaning solution will destroy the bimetal and the electric inside the built-in-one printhead.
Do use only dye ink for brother printers. In fact there is a filter inside the printhead in front of the nozzels. pigmented ink has particles (which give the color to the "water" where dye ink is already "colored water" without partikles!) which definitley cloggs the filter and therefor the nozzels! The filter cant be cleaned because its part of the printhead.
The machine has a counter built in which counts the cleaning cycles of the machine. There are small clying cycles which the machine does by start printing (some 0.5 ml will be waisted) and the manual cleaning cycle started by user which needs a 3ml amount of ink.
The machine has a built in waistinktank like all inkjet printers have. The engineers of brother have set the counter to an amount of taking up cleaning ink that will last for 2.5 - 3 years in normal use (and using original ink!). When the waistinktank has taken up the max of ink the machine will display error:cleaning and refuses to print anymore. The tank has to be replaced and the error (error 46/error:cleaning) has to be deleted within the eeprom.
Some solutions:
Run the cleaning cycle twice with original brother ink carts placed in the printer.
If you are lucky the nozzels (or filter) will be trouble free again.
If you dont see any success the printhead (or partially the filter) is clogged and has to be replaced by a new one.
Do use only (empty) original ink carts with a refill dye ink. Mix it up (:-)) with a trace of printhead cleaning solution by 1:10 for the C/Y/M colors only. You can refill an amount of 11 ml (1 ml cleaning solution + 10 ml ink) into the C/Y/M ones and an ink-only of 20 ml into the bk one.
In case the waistinktank is filled up and error sign appears search the forum here for error 46 and buy a new waistinktank as a spare part from a service dealer.
What should i do when the black ink wont work while other dyes work??? Whenever i used to print the black seems to be dotted or incomplete in process... If there is any dealer here in Manila where i can go to ask more information about the troubleshoot I'm undergoing please do tell me the address... Thank you very much...
Posted on Oct 22, 2012
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
How does one 'colour test' please.
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink button on the control panel and select CLEANING press OK.
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps Please rate if it worked Thanks!
Apr 03, 2011 | Brother MFC 490cw Color Inkjet...
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
When I test print, I do not get a full pattern of black dashes. I changed ink cartridges and have the same result. The color test prints are fine
If you are missing dots it is due to the print head not the cartridge.
Try doing a self cleaning a few times (max of 5) by pressing "ink" and select "cleaning"
If after 5 cleanings there's still a problem, you may need to have the printer serviced or replaced.
Since you're still getting most of your dots though, I think the cleanings should clear it out.
Thanks,
Pat
Mar 31, 2010 | Brother Multi-Function Center MFC-240C...
Brother dcp 150c pinting out of focus / blurry
YOu need to Do Print Test First I suspect One of the Color have Missing Dot..If the Print Quality have missing dot on The 4 colour the print our will blur ....The aligment of the print head maybe swicted ......Need to Be purge Or Replace new print Head...usually print head needed to be replace...
Nov 01, 2008 | Office Equipment & Supplies
After replacing the ink cartridges ran out I replaced them for new ones and the machine is not telling me that cartridges are empty tried and tried to rereplace them and I still keep getting the same
  1. Press the Menu/Set key.
  2. Press the up or down navigation key until TEST PRINT appears on the LCD.
  3. Press Fax Start. The DCP/MFC begins printing the Print Quality Test Sheet.
  4. By reviewing this Test Sheet, you can determine if the print quality or alignment needs improvement or adjustment.
StepA - Checking the print quality:
  1. The display will read "IS STEP "A" OK?" 1.YES 2. NO.
    Before choosing YES or NO, closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and proceed to StepB. If you can see missing short lines, press 2 (NO).
  2. The display will then ask you if the print quality is OK for each color. Press 2(NO) for any color with the problem.
  3. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1(YES) and the DCP/MFC will start cleaning the color ink cartridges.
  4. After the cleaning is finished, press Fax Start. The DCP/MFC will print another Print Quality Test Sheet.
  5. If you can see missing short lines in any of the four color blocks press 2 (NO) and repea the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
StepB - Setting the Alignment:
  1. The display will then read "IS STEP "B" OK?".
  2. Examine the 600 DPI and 1200 DPI test prints on the Print Quality Test Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1(YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  3. Print another Print Quality Test Sheet by following the steps provided at the top of this page and check it.
  4. Press Stop/Exit.
Aug 11, 2008 | Brother MFC 420CN All-In-One InkJet...
No black ink prints but colors almost perfect
Sorry, no good news: Infact you need a new printhead. The refill ink has clogged the filter inside the head which is in front of the nozzles. Another reason could be: Did you unplug the printer from power in those weeks of none use? If yes, the head has dryed out. In future: Do one simple test print once a week when you dont use the printer too often. That keeps the nozzles going :) There is some hope, too: See here how to fix it on your own http://www.fixya.com/support/t209702-get_color_print_black_works_fine (Following the link given to hstt.net : choose mfc 215c inside)
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
3,831 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
