Question about LG Nb3520 Nb3520a Sound Bar Audio System With Wireless Subwoofer
Lost connection how to factory reset? because my woofer not connection..
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Creative SBS 2.1 370 Speaker. hello how are you today, i have a question regarding the wiring in the volume on and off switch in the Creative SBS 2.1 370 Speaker setup, ive lost the little contoller some...
posted by Sandeep Sharma
hai, Here is the solution. when u cut the PCB from both sides u will find 4 cables i.e. green blue yellow and a copper wire coming from woofer and 3 cables white, red, yellow coming from audio lead. connect the green cable to copper cable and yellow to blue coming from woofer. Now take white cable coming from audio jack.connect this with yellow blue cables of woofer. Now attach Red and Yellow, connect these to green and copper cables of woofer and enjoy. if problem persist then make experiment to make interchanges with red white yellow coming from audio lead to the 2 sections of woofer side. woofer connections green/copper and yellow/blue remain same.
an.astrologer@gmail.com
Aug 30, 2011 | Creative Labs SBS 370 Computer Speakers
I need to locate and change my password
There is no way to recover the lost password However, you can reset the router to factory defaults and re-configure settings like password, network key etc. First, to reset the router to factory default setting, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer here to download the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | D-Link AirPlus DI-524 Wireless Router
Lost password
•Connect the power cord
•Unplug ALL Ethernet connections
•Hold down the reset button for at least 15 seconds
This will reset your router to factory defaults. •Open Internet Explorer (with the computer connected to the Router)•Enter 192.168.1.1 into the Address Bar, push Enter•If 192.168.1.1 does not appear to work, try 192.168.0.1•Under the Username field enter "admin"•Under the password field enter "password"•Click "OK"
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Dec 05, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
I've lost my security key, and I cant find it! Hoe do I connect my laptop tp my cumputer if I cant remebmer it?!
If you have a router, then you need to do a factory reset of it. I would also suggest you upgrade that surfboard to at least a 5100 series or better. The factory reset is somewhere on the back of the "router" not the modem. It is a pinhole that you push with a pen extended. This will take the admin settings and security setting off and reset the admin to factory default. Once you do this you are going to either connect without security settings or determine the factory default admin settings and reset all security again.
Nov 06, 2010 | Arris SURFboard SB4100 (46977600100) Modem
Internal wiring schematic for a JBL 4311 WX-A
the conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
And connect the tweeter at the empty output
Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
Feb 16, 2010 | Audio Players & Recorders
JVC KD-PDR30 overheating
think the sub woofer my be drawing to much power try disconnecting the sub for a few days and see how it goes
May 21, 2009 | JVC KD-PDR30 CD Player
Lost woofer in one cabinet.
I'm not familiar with your specific model, but some of these have fuses for the woofers. Check for a blown safety fuse. Also, verify that the connections to the crossover board are in good shape. These crossovers are not that complex and don't usually fail. Keep us posted on what you find.
Dan
May 29, 2008 | Recoton Advent Advent Calypso Main /...
LG Nb3520 Nb3520a Sound Bar Audio System With Wireless Subwoofer Logo
54 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
