Question about Flojet Quad Series Water System Pump Diaphragm Kit for 4405 / 4325 Pumps - Flojet
Water pump gives a brief burst of "on" every 10 minutes or so even when taps not activated
Water pump gives a brief burst of "on" every 10 minutes or so even though the taps are not activated. There are no leaks, plenty of voltage and tanks are full.
  • 466 Answers
It could be leaky check valve . The check valve keeps water from run back into the tank. It may be stuck partway open or dirt or scale may be keeping the valve from shutting tight . Hope this helps.
Posted on Dec 26, 2013
I got this iron for christmas, it shot steam 2 times and thats all. I had it set on cotton, linen. I used reg bottled water, should i use tap and why no shots of steam.
take it back for a warranty exchange after you check that the thermostat setting is on steam
distilled water is recommended for irons
bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
Jan 02, 2016 | Oliso TG-1100 Continuous & Burst of Steam...
No water
Does the motor turn it self off after a couple of minutes of no pumping?= ran out of water. If there is water up to the pump and still no water, check filter/s ( if there is any). Undo V band and check pump internals, impeller may be broken from shaft? When putting back together tap V band with block off wood or back of screw driver evenly as you do up the clamp to stop it distorting
Apr 14, 2014 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Hello, I have a fisher and Paykel washing machine that when you start a cycle lets in short bursts of water for 5 or so bursts and then just stops and beeps continually. Each burst lasts approximately 1...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
So check the inlet valve , check the inlet filter, it seems there is low flow due to a block and so remove and check the flow before you connect.
Now check the rest of the functions.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 12, 2011 | Washing Machines
I don't get enough water through the pump to keep it running with pressure. Pump cycles on and off.
unfortunately this is rather common problem, there is several solutions, none easy. i assume that you already cleaned inlet filter and connection hose is good diameter. check your mains if it is fully open (open tap in full then back half turn), same with tap connected to your supply hose. try to re-locate washer as close as possible to your mains connector. do bear in mind that these washers require at least 2gallons of water per minute (9 litres per minute)
if this solution do not work, or it is not feasible, find some 20 litres (5gallon) canister which can survive mains pressure, connect it with very short hose to your pressure washer and other end to mains, i know this is not an ideal solution but it will give you about 3min bursts.
if you find my advice helpful, please do not hesitate to comment and leave voe4 for me, thanx!
Jul 31, 2010 | McCulloch Garden
Our temperature control isn't working. If we put
You must have water to both inlets. Even with cold/cold, Your washer will mix the water some. Detergent will not activate if your water is extremely cold as it comes straight from the ground.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No water from the faucet over a minute when the water pump starts
First and foremost, check if your water pressure is between 20 to 40 psi. If it is, there is no reason why
you could not have water in your faucet. Check your
faucet and your pipelines for closed valve or a clogged
pipeline. However, even if the water pump pressure is
only 10 psi, it should reach your faucet. 10 psi pressure is equivalent to 23.1 feet vertical height.
So, please check it up and get back to us by e-mail.
Jul 12, 2009 | Flotec Corrosion Resistant Shallow Well...
Dishwasher starts running for 2 minutes then stops
The first 2 minutes of the cycle is a pump out cycle followed by a brief pause then a water fill cycle.Make sure the water is getting to the water valve underneath. Check the water valve for power with a volt meter just after the pump out cycle. No power= bad timer or bad wire. Power = a bad water valve or no water present.
Jul 05, 2009 | Whirlpool Dishwashers
Toilet pumps bursts of water
either your fill valve needs replaced or your flush valve needs replaced
May 13, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Flojet Quad Series Water System Pump Diaphragm Kit for 4405 / 4325 Pumps - Flojet Logo
392 people viewed this question
Top Flojet Plumbing Experts
Andrew Taylor
Andrew Taylor
richie46
Bill Boyd
Are you a Flojet Plumbing Expert? Answer questions, earn points and help others
