Question about Pool & Spa
The green lights won't go on after cleaning the chlorinator cell
    Problem Solver:
  • 7 Answers
What brand is the salt cell and power station? And how old is it?
Posted on Dec 27, 2013
3 Suggested Answers
  • 297 Answers
SOURCE: no green light....no chlorine generation
make sure you have at least 3000ppm of salt content'
set your timer for generation - the green chlorine light will not come on for at least 5 minutes sometimes up to ten
make sure you run the generator for at least 4-6 hours the first time
Posted on Jul 21, 2009
  • 297 Answers
SOURCE: I have an intex salt water system and having
Sit back and drink a cup of coffee or your favorite beverage, this may take some time to read.
First off it is a must that your salt level is at or as close to 3000ppm as possible.
Over around 3800ppm and salt will not efficiently be made
under 2700 or so you will get the same result.
Neither one will necessarily trigger the alarms.
Next possible
Do you have a stabilizer in the pool?
It is very important to have stabilizer. This helps hold the chlorine level
Most possible
The intex pumps are not strong enough to handle the pool volumes.
Take for instance you need to turn a pool over AT LEAST 3 times as quickly as possible if you have a 5000gl pool and a 2500gl filter per hour thats 6 hours alone that you should be running your filter alone.
Ad to that trying to generate chlorine When generating chlorine your pump slows down so you are not filtering on the level needed.
depending on how hot the day was,how many bathers,did it rain at all, Was kims hair full of hair products, and the killer sun tan lotion
All of these have affects
the usual generating time is between 5-8 hours sometimes longer depending on the above situations.
and dont forget the stabilizer
Bottom line this is what I do with an 18x52
I run the generator some time in the late evening 10-7 11-8 whatever it takes. once you start testing and see how low and then run it for x amount of hours and then see how low it goes again the next day you will be able to start gauging how long to run it. Once the unit is done unplug it and re plug this resets it to filter only now run that until you are ready to set the generator again and continue to do this the whole summer
Yes you need to run that thing 24 hours a day. It is no worse than having a 40 watt bulb on continuous.
remeber also that a pools worst enemy is not getting used. If that is the case LITTLE USAGE then you should be brushing your pool daily
one last thing get a good non foaming algecide about 15 dollars for 32 ounces you will use from 12-24 ounces just follow the directions and a bottle of something like crystal clear this product helps all the small particles to clump together thus easier for the filter cartridge to grab and do its job. Not noticable to the naked eye
Hope this helps and I appologize for the structure of this post I am not much of a writer
Mark
Posted on Jun 15, 2010
Auto chlor RP 92 QT
Just a note, if water is cold, there is an Automatic "Stays Off" mode when water temperature is cold. Chlorine won't be generated with cold water. Can't remember what "Number" that is, but unit will not turn on with cold water.
Dec 26, 2013 | Pool & Spa
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
Water is light green color
Need to turn up your cycle time.. Set your pump to run at 12 hrs and chlorinator at 10 hrs until the water clears up and then reduce to maintain the chlorine level... Make sure you keep the filter and electrolytic cell clean...
Aug 03, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Green light will not come on chemicals are fine
You may have a chlorinator cell that needs cleaning. I usually use muriatic acid diluted 4 to1. Find something you can submerge the cell in and be careful of the acid. If this doesn't help then there is probably something wrong with the cell or the control box.
Happy pool management.
Aug 07, 2009 | Intex Automatic Salt Water System for ...
No warning code, green light on but no chlorine produced???????
make sure your ppm is at least 3000 low salt may not trigger an alarm but is not sufficient for generating chlorine
also make sure you are running the generator for at least 4-6 hours to give the chlorine time to register
the system itself blows out very minute amounts of chlorine but build up after hours of being on
Jul 20, 2009 | Intex Automatic Salt Water System for ...
No green light....no chlorine generation
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Intex system not giving chlorine, no errors but no green light
I found I had the same problem. I would set the hours, it would count them down but the green light would NOT come on indicating it was producing chlorine, yet the sleep light would light up after the count down so I knew the light was working. I checked my salt, made adjustments, had to do shock treatments to keep it clean. Today I  found out that the manual is incorrect in how it says to set it. After you set the hours, instead of pushing both the arrows at the same time until it beeps, push the down button until it beeps, and then the up button until it beeps. For 2 months I have fussed with this system, and finally the green light came on and my test strips indicate it is producing chlorine. Yeah! To bad intex does not seem to mention this on their web site.
Good Luck
Pool & Spa Logo
13 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
