Question about Ricoh Office Equipment & Supplies
Sc 290 error code for ricoh mpc3500 - Ricoh Office Equipment & Supplies
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
  • 393 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Ricoh mpc3500 fuser unit setting error
Most common problem is the electrical connector on the fusing unit or the connector that the fusing unit connects to inside the machine is broken. So when you push the Fusing Unit in to the machine the connector moves out of position and doesn't connect properly.
Aug 01, 2016 | Ricoh MPC3500
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Mar 14, 2015 | Ricoh Aficio MPC3500
Error code J001 shows up after a jam
ricoh mpc3500 paper jam j001 which sensor ,no have inside paper
Jul 06, 2011 | Ricoh Aficio 250 Copier
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
Error codes SC580 ricoh mpc3500, how can you solve?
Is the supply voltage ok?
The problem is to do with the IH inverter (it is part of the fusing unit).
Any cables loose?
Feb 16, 2010 | Ricoh Office Equipment & Supplies
Error codes SC548 ricoh mpc3500, how can you solve?
The error means - Fusing unit rotation error.
Check if the fusing unit(right door{hot unit}) ,if it is rotating properly.
There could also be a sensor on the frame or the machine which senses the fusing unit rotation,(the sensor sometimes comes off)(remove the fusing unit and check where the fusing unit is seated).
Also try cleaning the sensor with a blower or brush.
Feb 13, 2010 | Ricoh Office Equipment & Supplies
162 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
