Question about HP Pavilion dv9000z Notebook
Dv9920us motherboard check
No fan, no hdd noise, no lights
    Top Expert:
  • HP Master
  • 22,688 Answers
Remove the power supply, battery, hard drive and RAM. Connect the power supply on its own and press power on. If it now goes to the first screen, add the RAM and then the hard drive. If it did nothing, I would suspect the GPU has unsoldered itself from the motherboard due to overheating.
Posted on Dec 26, 2013
Dv9920us won't start
Probably dead motherboard or ac circuit adapter.
In both occasions an expert should dissasemble your laptop to check whether the problem is exactly.
Dec 23, 2013 | HP Pavilion dv9000z Notebook
Powerlights and battery charge,ok. Still won't start
Hi, Could be HDD problem. Take to shop for repair. Laptop was or is over heating. Clean out vents. Don't put laptop on pillows or soft places only on hard table tops. Hope that helps.
Dec 21, 2013 | HP Pavilion DV9920US Laptop
My HP Pavilion dv9920us 17 inch Notebook PC becomes super warm when I am using it for longer than 15 minutes, even when I have it on a laptop cooling pad. It becomes so warm that even the keys on the...
Your laptop need to service. Clean and remove all dusk inside your laptop and your laptop will be fine after all dusk at CPU fan is clean.
Thanks
Jun 27, 2011 | HP Pavilion DV9920US Laptop
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
Powers up (fan noise & power light) then fan stops. No video output (even to external monitor) no HDD noise. Is this the motherboard? If so, what price am I looking at for repair?
I suggest that there is some problem with the hardware and you need to replace the hard disk drive.
If you can borrow from a friend or from a repair shop to test other HDD and it works again. that would be the problem. You need to located which hardware cause the problem.
Jan 10, 2011 | Acer Aspire 4520-5803 Laptop
Fans work green light shows on motherboard but cpu wont power up
Any HDD light on / if not could be failed HDD OR faulty IDE / Sata cable.
Did you get posting beep if not remove / replace ram / reboot.
If you did then either mobo / CPU may be faulty.
May 10, 2010 | Intel D845GVSR Motherboard
Fan running blank screen cant get into bios.was ok now this
Lets not jump to conclusions. Personally I feel that if give it a thorough cleanup without removing the Processor from under the heat sink, clean all the contact points, specially the power connection to your HDD(if its SATA it will make faster noises) and this could be due corrupted OS files too, but if the noise in the HDD persists, then its advisable to replace it if still under warranty, else use any working HDD and check to see if the same thing happens again. Don;t forget to repair your OS first. Also do checkdisk yiur HDD partitions particularly the one where the OS is installed and if it throws uo any bad sectors then the first thing to do is install the OS on a different partion. If it behaves properly then you have to make a desicion regarding repairing/replacing the HDD.....sodeep
Mar 31, 2009 | Acer (ACERMOTHERBOARD)
HP Pavilion dv9000z Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
