Lock code for your motorola transceiver - Computers & Internet
Where Is the anti theft module
Passive Anti-Theft System (PATS) Transceiver module is around the key lock cylinder behind or under the plastic cover on the upper steering column'
Passive Anti-Theft System (PATS) Transceiver Removal
  1. s4h~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
    Disconnect the battery ground cable, Refer to Section 414-01
  1. Remove the ignition switch lock cylinder.
    1. Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
    1. Push the ignition switch lock cylinder release tab with a punch while pulling out the ignition switch lock cylinder.
    2. If equipped, remove the tilt wheel handle.
    3. Remove the upper and lower steering column shrouds.
      1. Remove the screws.
      1. Remove the upper and lower steering column shroud.
      2. Remove the lower instrument panel steering column cover.
        1. Remove the lower instrument panel steering column cover.
        2. Remove the instrument panel steering column opening cover reinforcement.
          1. Remove the bolts.
          1. Remove the instrument panel steering column opening cover reinforcement.
          2. Remove the anti-theft transceiver module.
            1. Remove the screw from the bottom of the transceiver module.
            1. NOTE: Only apply pressure or leverage below the key cylinder lower rib.
              Disconnect the electrical connector and remove the module.
Dec 24, 2014 | 2006 Ford Taurus
How do you configure a motorola cdr-500 repeater?
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
May 29, 2014 | Motorola HKLN4060A - CDR500 Repeater
My motorola MH230R radios won't talk to each other. One receives, but the other doesn't.
Try to clean the contact point of the antenna of both the transceiver. There might be a foreign object which clog the signal to be fed...if the problem still exist. The possible reason is one of the transceiver has a defective amplifier circuit...
Call a technician to locate the repair the problem
Sep 19, 2011 | Motorola MH230R Two Way Radio
PLS UNLOCK MY W300I SONY ERICSSON ITS AUTOLOCK
This can be easily unlocked using the code , if it's network lock.. I found the site http://www.superunlockcodes.com/sony-ericsson-w300i/rs12wp9/ .This site provides the unlocking code & instructions for your Sony Ericsson..By using this you can unlock your mobile easily..
Feb 28, 2010 | Jabra Sony Ericsson W300 / w300i / W550i /...
Have Motorola H680 blue tooth hands free transceiver for ear. Need to increase volume and can't find a way to bypass their volume limits
This would have to be a modification or hack which voids your warranty, if you have one. I can't give you information to hack or modify your blue tooth but I can tell you its a service that you would need to have done via the internet or a local friend.
Good luck,
Brandonmxb
Dec 10, 2009 | Motorola Mobility Bluetooth Hands Free...
Where do i put the memory card in i cant find a place to put a san disk memory card into the motorola
are you sure the motorola is using a memory card?if not you can insert the memory card. but if it has the space it is either at the side or at the back of the battery.
Aug 09, 2009 | Memory Upgrades 1000blx/lh Long Haul Gbic...
My w270 motorola handset don't work my computer &do not support
Generic problem for all Motorola Networking Repeaters My w270 motorola handset don't work my computer
Apr 12, 2009 | Motorola Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
