Question about Samsung RF4287HARS French Door Refrigerator
40 E Code samsung refridgerator - Samsung RF4287HARS French Door Refrigerator
The ice maker in my Samsung French door refridgerator keeps getting frozen up. Help
hi Delunn.
this could be a couple of things wring.
so i think it best you go to this link and see if it helps you out.
ice maker in my Samsung French door refridgerator keeps getting frozen up...
Dec 02, 2017 | Samsung Refrigerators
How do you reset error code 22E on Samsung refridgerator
put it off and then power it on and use the settings botton for reset.
Oct 10, 2017 | Samsung Refrigerators
Samsung refridgerator not cooling
If it's flashing error code "OF" "OF" Try pressing the energy save and freezer button at the same time. this worked for me.
Aug 11, 2014 | Samsung RS265TDBP Side by Side...
Samsung RF217ACBP keeps freezing the ports inside the refridgerator. Then the fan motor starts
Their is a fan circulating air through out the unit. If this fan is not working you will experience what you have discribed.
Jul 21, 2014 | Samsung Rf217acbp Black 20 Cu.ft. 33"...
Need remote code for samsung 5.1 home theater surround sound model#HWC560S
Welcome to Fixya. I would like to know who is the provider of the remote so we can provide you with the code. example: AT&T, Comcast or etc.
Please provide the information needed to be able to fix the issue.
Thanks
Sep 03, 2011 | Samsung Audio Players & Recorders
Our flat samsung 40 inch just clinks won;t come on
REPLACE 3 -4 CAPACITORS IN THE POWER SUPPLY, THEY ARE SWOLLEN UP OR LEAKY
Dec 30, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Refridgerator won't cool, freezer is OK
if it is a bottom freezer and top refrigerator it is low gas in the system need to be topped up
May 12, 2009 | Samsung Refrigerators
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Refridgerator side of my refridgerator keeps freezing my food
The problem may be low gas or it may be the thermostat is set too low.  First, look at the possibility that you may have the food partly blocking an air channel which is where the very cold air is coming from..  Fridge side should read about 40 F after the door is closed for about an hour.  If colder, adjust.
Nov 15, 2008 | Refrigerators
Samsung RF4287HARS French Door Refrigerator Logo
291 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
