Question about Electrolux EW1000i Front Load Washer
Suddenly stopped My front loader suddenly stopped during a wash. all the lights went off the power is plugged in and it makes a very quiet humming noise when I try to get it going but no lights at all. There hasn't been a power surge. Any suggestions
  • Official Brand Answer
  • 4,342 Answers
Hi Kim, thank you for your post!
Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. Since you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Best regards, Chris!
Posted on Jan 03, 2014
2 Suggested Answers
  • 6 Answers
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Posted on Dec 05, 2010
The lock light turns on but it wont start
Had similar problem. I removed bottom front panel, took plug out let it drain then removed trash in it(coins,screws,just random stuff). Went a step further took pump out and removed back off it and found Bobby pins stuck in it. Put all back together and works fine. Make sure to have towels for when removing plug
Jun 06, 2012 | GE WSXH208A Front Load Washer
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
My 3 year old front loader suddenly stopped draining, spinning, and now the door will not unlock. It still has power and you can hear clicking, it does cycle through wash, but stops at drain and lights...
This looks like the pump is blocked or drain or the pump has gone. to try and solve it best thing to do is open pump filter usually on bottom front of machine to access pump water will come out so be ready. when you have opened the filter you can check for a blockage and give it a clean put filter back on and put it on a cycle and see if it drains. to make door open start a cycle stop it after a few seconds of being on and turn off machine on machine not at plug and leave it for a while it should open. if it does not then switch off for 5 mins and back on and repeat it hope this helps.
Sep 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Started washing machine; suddenly stopped drawing water
If you are certain there is water up to the inlet valve, and you can hear it humming, then there are 3 possible reasons.
  • The valve is not opening because it is stuck.Replace valve.
  • Check inlet of valve for a possible clogged filter, remove and clean.
  • Insuficient water pressure to open valve.
  • Plz rate my solution.
  • Thanks.
Jan 13, 2009 | Maytag LSE7806A Top Load Stacked...
Front Loader Frigidaire will not drain model no. LTF530FSO
check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Electrolux EW1000i Front Load Washer Logo
61 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
