Runtka448wjqz I have a sharp lc-32sb23u and when I turn it on it will shut off after about ten min. Is the power board runtka448wjqz that is shutting the tv off.
  • 1 more comment
  • Mark Koji
    Mark Koji Dec 26, 2013
    Hi Mark Koji, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Mark Koji
    What info do you need ?
  • Mark Koji
  • Televison & ... Master
  • 10,291 Answers
Check all the voltages before and after the tv shuts down. If they don't change then the power supply board is ok. Look to the main board because that's what actually turns the tv off
Posted on Jan 06, 2014
SOURCE: connecting external speakers to Sharp LC-32SB23U
Invest in a sharp soundbar (about $175.00) matchs the cecor of the TV fits right at the bottom and looks like part of the TV and the sound is super.
Posted on Jun 04, 2009
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
  • 3 Answers
SOURCE: my sharp lc 32d42u shut off and won't turn back on
IF YOU STILL HAVE SOUND I AM PRETTY SURE WHAT THE PROBLEM IS...
Posted on Nov 20, 2009
  • 117 Answers
SOURCE: My Sharp Aquos LC-52D64U shut off by itself, and
sounds like power supply/ohm supplies for repair in uk
Posted on Nov 23, 2009
  • 41 Answers
SOURCE: Shuts off
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
I have a Sharp LC-32SB23U TV and the power light just blink. What is wrong with it?
It has a bad T-Con or a bad main board. Check on ebay for a board with the description and model number of your TV.
Jan 02, 2018 | Sharp Televison & Video
Is the audio amp on the main board of a sharp lcd tv
A manual for a measure of the voltage line thats goes to the audioboard and there can be used a fuseresistor a resistor to protect the audioboard if .......
SHARP LC 32M44L LC 32SBB21U LC 32SB23U LC 32SB220U SUPP Service Manual...
Suc6
Oct 25, 2015 | Sharp LC-32SB23U 32 in. LCD TV
Sharp aquos lc-37gv5u sound shuts off after ten min. of starting
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 25, 2012 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Green lightflashing on my sharp lc-32sb23u how do i fix it....
You might have a bad CCFL lamp, part #RLMPLA029WJN1, inside the LCD panel or maybe a bad power supply inverter board, part # RUNTKA448WJQZ. Both are easy to check and replace yourself. You will have to take the tv apart to replace these. Check for bad CCFL lamp first cause they cost about $19.49 ea. If you take this tv to a Sharp TV Service repair center they will tell you the LCD panel is bad and they will want to charge you $800.00 for it.
Mar 30, 2011 | Sharp LC-32SB23U 32 in. LCD TV
The power light blinks and the tv doesn't turn on
you should perform the initialization to factory defaults.
May 24, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Tv takes forever to turn on sharp television LC-32SB23U
This problems very common with sharp tv.The Main Turner Signal board have problems.Keep using it,when it stop and completely dead 20-30 on-off no backlight show up and picture.U know ur Tuner board signal board is dead, have to replaced it.
Jan 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Can't Find the Operation Manual for Sharp LCD TV Model LC-32D47U
Try to download the manual from this link if your LCD is the LC-32SB23U.
Sep 19, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Connecting external speakers to Sharp LC-32SB23U
Jan 04, 2009 | Sharp Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
