Question about Craig Tower Speaker System For iPod, iPhone, iPad - CHT910
The tv sound wont come out of the speaker with the cables hooked up
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
Jan 27, 2015 | Logitech X-540 Multimedia Surround Sound...
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
No sound on my fujitsu 50" plasma TV
its not hooked up right your cable box or tv manual should show you how, cable audio out, tv audio in left and right
Jun 15, 2013 | Fujitsu P50XHA10 50 in. Plasma Television
I have no sound coming out of my speakers for the reciever that is hooked up to my tv. i have 2 of the spekers hooked up and the audio cable plugged in to the tv but im getting no sound from the tv t
hi,try going into your tv setting and see if thers a setting for ext speaker as sometime ther is ,this is the place i would look and the only place i would think the fault would be ,you say audio cable i take it you mean
rca cables [two cables] if not check them but i dont think its both of them faulty,def in setting somewere.good luck
Jan 21, 2013 | Kenwood Audio Players & Recorders
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
No audio from cable through surround sound
you have to go to the setup for the TV audio and change it to audio out, not speakers.
May 07, 2009 | Philips Televison & Video
Tv hook up!?
First you must be on the audio outs in back of tv set. then you must go into menu, if not already and change audio to varible output, or external speakers or just what ever yours say in menu. then you must turn receiver to the right inputs to get sound. Hope this helps.
Sep 21, 2007 | Panasonic SA-HE100 Receiver
Craig Tower Speaker System For iPod, iPhone, iPad - CHT910 Logo
18 people viewed this question
Top Craig Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Steve F
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
