I need to change the ink cartridge for the first time, and i don't want to break anything
  • kaymulhall May 23, 2009
    i want to know how to remove old cartridge and replace new one. on HPDeskjet D1460 printer
    Problem Solver:
  • 8 Answers
Follow the manual or call service centre
Posted on May 17, 2009
  • Bpm Kumaran May 17, 2009
    follow the manual or call service centre
My CANON IR 2520 PRINTING VERY DARK SHEET AND SHOW ERROR CODE E000110 THANKS
Try removing ink cartridges and see if anything changes. If printer starts working fine, check which ink cartridge is bad by putting one at a time, or just change ink cartridges.
Jun 09, 2017 | Canon Office Equipment & Supplies
The printer wont let me do anything because it says I have an alignment problem and to take the tape off of ink cartridge but there is no tape! Its not a new cartridge I don't know what its talking...
May be dry the ink or refill ink cartridge so , it could't properly ink out the nozzle. If possible u can batter manually clean the print head. Then try to it. Otherwise need to change the ink cartridge.
Jun 13, 2013 | Office Equipment & Supplies
How to change printer cartridge Dell 810
Open the printer cover with it turned on and connected to your pc. When you open the cover, the printer should bring the ink cartridge carrier to the front and center so you can access cartridges easily. Press or pull the plastic tab next to the ink cartridge that you wish to replace and it will pop it up towards you and out of the carriage. if there is no plastic tab to eject the cartridge, grab a hold of it with your finger and pull upward and out towards you. Don't worry about breaking anything or harming the cartridge. Once you remove the old one, remove the plastic tape tab on the new cartridge before inserting. Then close the printer cover and it should walk you through aligning the print heads on the display. Good luck!
Oct 09, 2011 | Dell 810 All-In-One InkJet Printer
My officejet keeps saying we have to change the ink jet cartridge, which i have done... and when you hit continue or ok it doesn't advance. I have to turn it off and on again in order to do anything,...
this inkjet has ink cartridges on the left side under the hatch with each seperate color inside, it also have the cartridge with the inkjet heads on that you found when lifting the printers top up. wich one did you change?
Aug 17, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Replaced ink and it still shows replace ink
I have the same problem at times. After putting new ink in you need to spool it. Call brother help line for free and they will tell you how to do this. I am sorry I don't remember how- sometimes turning it off and on will help. Also, I have noticed that if you put it in too quickly it will not recognize it. Try some of these. Spooling is the best try going to your control center and check all options!!!
Hope it helps-
Jul 23, 2011 | Brother Office Equipment & Supplies
How do I know how much ink is left in my c3135 printer
Welcome to Fixya.
Here's how to determine the ink levels for your inkjet printer :
HPC3135 Ink Level check
Please see my additional reminders :
  • If the printing quality diminishes, it's a good time to check your ink levels.
  • Change your cartridge often for good printing quality.
  • If you refill the cartridge, the ink level indicator may not be accurate.
  • Don't wait until the last minute to change your cartridge.
Thanks for using Fixya.
Jun 05, 2011 | HP Photosmart C3135 All-In-One InkJet...
My c543dn insists that the cyan cartrige is missing but its not- any help here ?
These would be my recommendations, based on problems I've had with a similar printer:
1) Open the printer and pull the cyan cartridge back out.
2) Check the bottom of the cartridge to make sure there aren't any scraps of plastic or other material that might be preventing the printer from recognizing it.
3) Check inside the ink well (where the cartridge goes) to make sure nothing's stuck down in there that might be preventing the connection. Be careful and use a flashlight so that you don't accidentally break anything else (I've done that before).
4) If all of that is clear, re-insert the ink cartridge and push down (not too hard, but firmly) until it clicks into place.
5) If none of that works, the leads on the cartridge might have been damaged, or it might just be defective. You'll probably need a replacement toner cartridge at that point.
Hope that helps!
May 07, 2011 | Lexmark C543DN Laser Printer
I changed ink cartridges and now the printer
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 13, 2010 | Office Equipment & Supplies
MESSAGE 'CHECK INK U051 BLK COL'
just hold down the stop reset button for 10 seconds it will bypass the ink counter
Jun 05, 2009 | Canon PIXMA MP170 All-In-One InkJet...
My x1180, how do i change the ink cartridge
Here is a copy of the setup guide that should give you some good help:
X1100 Setup Guide
The cartridges are in cartridge carriers under the scanner unit cover.
Jan 12, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
138 people viewed this question
k24674
jasbo
jasbo
