Question about World Tech Toys Saturn-X 2-Channel RC Helicopter w/ Gyro, LED Lights, Durable Metal
Flying Saturn-x helicopter - what does the A B C mean on the remote?
Instructions not so clear.
Ir helicopter only upper wing spinning
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Dec 30, 2012 | Worldtech Devices World Tech 85618 2CH...
No power
Check the channels and make sure your on the right channel A / B usually..
give the blades a gentle turn with your fingers, they stick sometimes.
Dec 28, 2012 | FocalPrice BR6008 3.5-channel Infrared...
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
Hello i have rc helicopter it woring fine expect flying. the helicopter not going up. means not flying.
depening on the size of the copter if it is a motorized one then you need to check the pitch of the main rotors and check that the collective is working in conjunction with the increase of revs from the motor ie more revs = more lift
the amount of pitch required should be in the setting up instructions
hope this helps
Aug 06, 2011 | Toys
Helicopter not flying wont take off and is vibrating badly and just spinning on the floor
make sure that you read the manual, followed all the setup instructions( how to arrange the blades, how long to charge it for the first time, etc.) , and the helicopter is on a flat surface. If the problem persists contact the store to return it or the customer service of the company.
Mar 01, 2011 | SYMA Toys industrial New Syma S107 Radio...
Hello, i have problem with flying back and forvard, becouse rear propeller does not work. What is wrong and can i fix it? Thanks :)
Yes if the rear propeller does not work the helicopter cannot be made to turn around. So it is important that the rear rotor works.
Now make sure that the drive is working to let the motor work , if controlled by the remote make sure the remote command works or is a fault in the remote.
Check the mechanics of the rotor movement. reset.
Dec 31, 2010 | JCPenney Gyropter RC Helicopter
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
I crashed my Apache onto a table and when I try to fly it, It keeps spinning out of control. To my knowledge I don't see anything broken. It spins to the right. Please help! thanks!!!
It sounds like your tail rotor is acting up or missing. It keeps your Helicopter from flying in circles.
http://www.start-flying.com/new%20site/heli1.htm
Oct 04, 2010 | Apache RC Mini Helicopter AH-64
My john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Dec 30, 2009 | Toys
World Tech Toys Saturn-X 2-Channel RC Helicopter w/ Gyro, LED Lights, Durable Metal Logo
612 people viewed this question
Top World Tech Toys Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a World Tech Toys Craft and Hobby Expert? Answer questions, earn points and help others
