Question about Panasonic NN-P294SF Microwave Oven
Frigidaire microwave oven model fmv152ksa fan won't shut off
3 Suggested Answers
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
  • 1250 Answers
SOURCE: fan in microwave won't shut off
in most cases, it is the door switch. It usually has 2 micro switches and either one can go bad. Not a hard fix. I would look at the operation to see if the switches are working. If that is not it, could be in the circuit board. Could be too much to fix, maybe buy a new one if it is a counter top type. Otherwise let it run till it quits. Call a repair guy, and have him diagnose the problem. Tell him you will fix it in a month or two so could he write down what you need with the part numbers. This way you do not have to start at ground zero. Then order the parts and fix yourself if you feel brave enough.
Posted on Feb 07, 2009
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
When door is shut some type of internal fan kicks on...
Hello Derrick Baker - Typically no fan should come on without starting the microwave. There is one exception! For an example, if the microwave becomes too hot from something that is cooking on the stove below the microwave, the fan will come on and will cycle off once the bottom of the microwaves cools back down. If the fan is turning on when the door is closed, more than likely, a door switch as failed. At this point, I recommend connecting with a certified technician to move forward accurately to assist with the repairs.
Mar 09, 2013 | Frigidaire FMV157GM Microwave Oven
Door won't shut
Hello - Sounds like the microwave made possibly have a damaged or broken door latch. I suggest contacting a professional to move forward accurately and to assist with the repairs.
Jan 18, 2013 | Frigidaire FMV156DC Microwave Oven
We can put in the minutes and temp., then when we close the door the clock times down and the fan blows, but nothing cooks. Fridgidaire model cfmv156fmc. For a while if we put a piece of cardboard in by...
I threw mine away because frigidaire would not do anything for it and was less than 6 months old . local dealer would not look at it as we bought from a big box store not them .
Dec 09, 2017 | Frigidaire Microwave Microwave Oven
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
Frigidaire microwave model fmv152ksa Some of the buttons on the console do not work. The number 5 does not work (if I hit timer & any other #, the # will show up, but 5 will not show up) the clock on...
If you're saying that some digits or segments on the display do not light up, then I would first suspect grease or moisture on the control circuit board.
If it's just that some pads on the keypad will not respond, I would say your membrane keypad is failing.
I would first give it a "hard reset" by unplugging it for 2 minutes, then trying it again.
If it still fails, I would remove the control panel assembly (see the disassembly video here) and inspect the circuit board for green, gray, or white residue or grease.
The membrane keypad is not available as a separate part, but comes already installed on a new control panel frame, which is part number 5304464130 which you can order from the Pros here.
To replace that, you unplug the keypad (as per the photo below) and move your circuit board into your frame.
If you need more help, feel free to contact us directly.
Jan 27, 2011 | Frigidaire FMV152K Microwave Oven
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
