Question about Samsung ML-4551ND Printer
Fuser empty - Samsung ML-4551ND Printer
DSC224 printer displays low on fuser oil
There is a sensor that need to be cleaned if the code will not clear. I believe there is a black float that is part of the fuser bottle. If you swing out the oil bottle and look where the float would be... There is a sensor, clean the sensor and make sure it is plugged in correctly... Good Luck
May 22, 2012 | Gestetner DSc224 Copier
010-327 Fuser On Time Failure RAP
• After the Main Lamp turned On during warm up, the Control Thermistor did not detect
READY temperature within the specified time.
• After the Main Lamp turned On during standby, the Control Thermistor did not detect a
specific temperature within the specified time.
• After the Sub Lamp turned On during standby, the Control Thermistor did not detect a
• After the empty rotation started, the Control Thermistor did not detect the empty rotation
finishing temperature within the specified time.
• After the Main Lamp turned On during printing, the Control Thermistor did not detect a
• After the Sub Lamp turned On during printing, the Control Thermistor did not detect a specific
Initial Actions
Check for paper on the Fuser. The Fuser has no paper wrapped round it.
No)Remove the paper.
Yes)Check the installation of the Fuser Unit. The Fuser Unit is securely installed.
No)Install the Fuser Unit securely.
Yes)Remove the Fuser Unit. Check the conductivity of the contact points of the Thermostat. The
contact points are connected.
No)Replace the Fuser Unit
Yes)Check the resistance of the Main Lamp between P600-3 and P600-7 for an open circuit or a
short circuit . The resistance of the Main Lamp is 100 ohms or lower.
Yes)Check the resistance of the Sub Lamp between P600-1 and P600-7 for an open circuit or a
short circuit . The resistance of the Sub Lamp is 100 ohms or lower.
Yes)Check the resistance of the Control (Center) Thermistor between P600-5 and P600-6 . The resistance is 3k ohms or higher.
Yes)Check the resistance of the Rear Thermistor between P600-2 and P600-4 . The resistance is 3k ohms or higher.
Yes)Check the wire between J410 and J600 for an open circuit or a short circuit . The wire between J410 and J600 conducts with less than a few ohms.
No)Repair the open circuit or short circuit.
Yes)Check the wire between J6 and J600 for an open circuit or a short circuit . The wire between J6 and J600 conducts with less than a few ohms.
Yes)Check the wire between J401 and J523 for an open circuit or a short circuit .The wire between J401 and J523 conducts with less than a few ohms.
Yes)Replace the Fuser Unit . If the problem persists, replace the Power Unit . If the problem persists, replace the MCU PWB .
END
Aug 03, 2011 | Xerox WorkCentre PRO 128 Copier
After everything I print on my IR2030i a blank page comes off
Empty toner-cartridge?
Problem with "fuser" (the fuser heats up, and melts the toner-ink into the paper) not working ?
Take it to a qualified printer technician, for professional trouble-shooting.
Mar 17, 2011 | Office Equipment & Supplies
I have dark streaks with all print-outs on a Samsung ML-2510. It goes away on a new cartridge.
This is a common problem with a close-to-empty cart.
A new cartridge will have even toner, and will distribute it evenly to the page.
An older toner will start to streak and line onto the page.
Another issue could be the fuser... some of the new printers have a fuser built into the cart unit... so that when you replace the cartridge it replaces the fuser as well.
A fuser can become dirty and thus not distribute toner evenly across the page.
Cheers!
Feb 23, 2011 | Samsung ML-2510 Laser Printer
Xerox dc 3535 consumabel empty what i do for reset the consumable
tell exact word
consumables like ink, C, M,Y,K or what ?
Jul 01, 2010 | Xerox DocuColor 3535 Copier
Double images and dirty copies on left side of paper
This is caused by one of 2 things. It is either the toner cartridge or the fuser film is going bad. If you have a spare toner, even an empty one you can shake a little and try it to see if the double image goes away. If a different toner does the same thing then it is the fuser film. Now you can change you own fuser if you wish. Just don't let a service guy come out and tell you that you have to replace the whole fuser. You can have them replace just the fuser film because the rest of the fusing unit is usually just fine. I do fuser films all the time. $50 to $80 for a film vs. $200 and up for a fuser.
Good Luck and Thank You for using Fixya.
Apr 20, 2010 | HP LaserJet 2420 Printer
H6-00 IS SHOWING UP
Dear sir; H6-00error code on this machine , it means "fuser oil empty" you just add the fuser oil in it should be OK, if still have problem please let me know, otherwise be generouse give a rating.
Dec 22, 2008 | Sharp AR-C160 Color Copier
Cru fuser error
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
Jun 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Very old sharp z55 copier won't copy
It is most like a fuser error code. Do you see the heating lamp turn "On", If yes, it could be the thirmister. If dose not turn "On" it could be the thermal fuse or the fuser heating lamp.. The code will not reset till the problem is repaired.
May 09, 2008 | Office Equipment & Supplies
Samsung ML-4551ND Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
