Question about ASUS Computers & Internet
How do you eject the disk drive - ASUS Computers & Internet
    Top Expert:
  • ASUS Master
  • 23,773 Answers
Press the eject button on the front door of the drive.
Posted on Dec 26, 2013
How do eject disc from my mac os x
Every Mac that has an optical drive has an eject key on the keyboard. Pressing the eject key will eject a CD or DVD.
The eject key has this icon on it: ?
You can also right-click on the disk icon, then choose "Eject" from the pop-up menu.
You can also click once on the disk icon, then choose "Eject" from the File menu.
You can also drag the icon to the Trash icon in the dock.
The eject key will only eject CDs and DVDs, but all of the other methods described above will also unmount other media types, like a hard drive or flash drive connected via USB, FireWire, or Thunderbolt.
Aug 13, 2014 | Apple Mac OS X Snow Leopard (10.6.8)
Disk will not eject
Unplug the drive. insert a paperclip in the hole in the back of the drive. This will manually eject the disk. You can also open the cover but that's a lot more work than you need to go through when a simple paperclip will move the manual eject lever.
Jan 19, 2014 | Iomega Z100P2 External ZIP Drive
WD external hard drive mac
Sounds like your external drive might be bad. Try connecting it to another system and see what happens. If you can't get to read data on another system, the drive is bad.
May 29, 2012 | Western Digital My Book Essential Edition...
How to eject dvd disk samsung laptop no eject button?
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Apr 01, 2012 | Samsung NC10-14G Notebook
A disk appears to be stuck in the disc drive. It will not eject.
You should see a small hole next to the eject button on your drive. Take a paperclip and push it into that hole. It will force the drive to eject.
Mar 01, 2011 | Acer Computers & Internet
I have a disk in my apple computer that will not eject when I press the eject arrow
If you look carefully you will see a pin hole on your disk drive built in to your apple computer.
The disk inside the disk drive might be stuck or the there can be some damage in the disk driver. Either ways you can insert a sharp pointed object like a needle or a pin in the pin hole. This will eject the drive.
If the disk drive does not eject, to avoid any further possible damage the laptop has to opened and the disk drive has to be removed and inspected. If the above solution solved your problem, You disk drive may start to function properly otherwise if there is no hole (since many disk drivers have no holes) or the insertion and poking of needle does not work the only recommended option is that you have to take it Repair shop or give it to a tech.
Good Luck!
Jan 06, 2011 | Computers & Internet
How to eject a floppy disk from the external drive? It is stuck in the drive and can't remember how to get it out.
Sometimes the disk stops when ejecting, and remains in a slightly lifted position, making it impossible to eject it no matter what. It has to come back to it's resting place inside the drive and then you can try ejecting it again.
Try to push it back in with something that will not destroy the disk and the drive, like a piece of cardboard, or your finger, if you can reach inside.When it clicks back into place, try ejecting it again. Repeat a couple of times if necessary, it should unlatch eventually.
Nov 03, 2009 | Iomega (32453) External ZIP Drive
Zip drive does not eject the disk and will not power up.
To the left of the Eject Button/Activity Light is a Disk Eject Hole. It will be a very small hole big enough for you to straighten out a paperclip and push in to hit the eject the disk
Jul 20, 2009 | IBM Iomega ZIP 750 (22P7099) External ZIP...
My Iomega Rev drive keeps ejecting the disks I put into it. It has been backing up reliably for a few years now and recently it started ejecting every disk I put into it.
FWIW, I had the same problem...here's what I did.
I would insert a disk and it would get ejected immediately...didn't even look like the light in the eject button would flash. Rebooting the drive and computer didn't work.
I inserted a disk.
Before it could be ejected, I pulled the plug on the Rev Drive.
I waited several seconds
Re-plugged in the rev drive.
It seemed to read my disk and I was able to use my Rev drive. (So far so good...knock on my wooden head.)
Luck
- J
Jan 03, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
Can not eject zip disk
I have the imoga 100 external zip drive and there's a pin hole on the front panel. that if you straighten a paper clip and stick in the whole, it should manually eject the disk.
Jul 12, 2008 | Iomega (32453) External ZIP Drive
Computers & Internet Logo
19 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
