Question about Frigidaire FGQ1442ES Gas Dryer
Dryer turns on but there's no heat, is this a fuse issue and if so how to replace it?
  • csrbridget May 17, 2009
    yes, it is glowing
  • Frigidaire Master
  • 4,654 Answers
Need you to try a few things so we can see if the igniter is coming on. Gently pull the dryer away from wall so as not to break the gas line. Open a back panel on rear side and while starting dryer see if you see a glow from the igniter. Most times a pair of gas solenoids become weak over time and may need replaced. Let me know what you find, Sea Breeze
Posted on May 17, 2009
  • John Tripp
    John Tripp May 17, 2009
    OK, now we need to go a step further. Unplug dryer and turn the gas valve off on the back. Take a large flat head screw driver and on each corner of front left and right pry the top up until it pops open. Take care not to scratch paint on surface. Now gently lay the top back toward the back wall and let it sit there while you reach down inside front panel and unplug the 2 wires coming from the door switch. Then take a 1/4" nut driver and remove two sheet metal screws holding the front to the side frames. When they are out pry the front away from side frame like you did with top. You may need to open door and hold drum up as you take it off and for sure when you put front back on. Now lets go to the link below and I will point out the parts and how to fix your dryer. Put model number FGQ1442ES0 into the model search feature. You will see one dryer like your listed, click on that one. When you reach the page it takes you to on left side of screen you will see some part prints choose #11 That will be your burner compartment. When you get to that point you will see the solenoid valves on top of gas valve. Let me know when you are to that point, Sea Breeze
    click link below
    http://servicepartstec.blogspot.com/
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
AEQB6000ES2 dryer wont heat
There are 4 things that can cause this issue: 1. Thermal Fuse (Protects the dryer from overheating and fires) if this is blown, the drum will still turn but you will have no heat. {Cheapest Fix} 2. Heating Element Assembly {Third Cheapest} 3. High Limit Thermostat (if this is stuck OPEN, the dryer will not heat) {Second Cheapest but rare issue} 4. Main Control Board (Check all the other parts first as this is not cheap and there is no way to test it, if the other parts do not fix the issue, replace this. Not a common issue but can be a manufacturer defective item)
Feb 27, 2013 | Kitchen Appliances - Others
No heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 23, 2009 | Whirlpool LER5636P Electric Dryer
Gas dryer does not turn on , first it would not heat. but it did turn on and blow air but no heat . know it doesnt turn on at all.
HI, check the following to address this issue.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Sep 03, 2009 | Kenmore 73952 Gas Dryer
No heat, changed element, still no heat
((If the timer control module becomes unstable, it will also cause this no heat issue. If thermal fuse and thermostat are OK and in working order, replace the timer.(uncommon issue but possible)
Aug 13, 2009 | Dryers
INGLIS DRYER MODEL IP82000 RUNNING BUT NO HEAT.
2. Heating element
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.(((((Most common issue)))))
Aug 04, 2009 | Whirlpool Inglis IP8200 Dryer
29'' Kenmore electric dryer series 110 not heating up
Check the following to address this issue.(Most common issue will be a burned out thermal fuse.)
2. Heating element
3. Thermal fuse
Aug 03, 2009 | Dryers
Our Kenmore model 96292810 clothes dryer has stopped heating. What is the likely problem?
1. No power to the dryer(If you have power, skip to the next possible issue)
2. Heating element
3. Thermal fuse
Jul 18, 2009 | Dryers
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool Dryers
Not heating
you have a dead short somewhere or someone monkeyed around the dryer to repair it
Jun 18, 2009 | Amana DLE330RAW Electric Dryer
Frigidaire FGQ1442ES Gas Dryer Logo
136 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
