Question about Sakar Monster High Karaoke System 68148
No display on the screen
How do we get the words on the screen?
How to change text size
please clarify; what kind of operating system your using? text size of what? application software like word or Computer screen display? for windows screen text you can enlarge by entering control panel-appearance and personalization for win7&win8 - display make item small or larger or by changing screen resolution
May 01, 2014 | HP Mini 1000 Netbook
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
How can I copy the standby screen to Word Document, then probably edit it to paint?
I am not sure what exactly you mean when you say "Standby screen", if you mean the screen saver, then go to >display settings, > Screen Saver > then click Preview and while the preview is running, press "Print Screen" key on the keyboard, the image will be copied onto the clipboard, now close the display settings and paste it into the word document/paint.
We call this as "Screen Shot", you can also do the same with the desktop, suppose when you want to capture the image of your desktop, just press "print screen" key on the keyboard and paste it into the paint or other photo editing software and save it. Anything that you can see on the desktop/display of your monitor while the computer is running can be captured in the same way.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Microsoft Windows Vista Ultimate Edition
Can't see words displayed at bottom of screen
Check your menu for horozontal and vertical size adjustment to see if you can reduce the size of the image. Or try to change the aspect ratio. Last resort is to do a system reset.
Jan 16, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony dvp-ns425 player has the word VIDEO in upper right corner appear and disappear every 20 seconds or so. It is in the same green block letters as all the menu/control titles so I know it is from the dvd...
That word Video in green color could be TV's on-screen display as DVP-NS425 has another kind of on-screen display that has track info, time info etc in display.
Please press Display on TV remote to turn off that green color Video on-screen display at top right corner.
Thanks.
Sep 13, 2009 | Sony DVP-NS425P DVD Player
Removing words from main screen
I would say you would need to go in and change your settings. If you have an option to have a screen saver or not, that would probably be where you can change whatever comes up during idle mode.
Aug 30, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
"Factory" on display
Lets just buy her a new one. blv
Dec 18, 2007 | Samsung CXD1334 13 in. Combo
Protection displayed on screen
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Nov 08, 2005 | Samsung HT-DB120 System
Sakar Monster High Karaoke System 68148 Logo
20 people viewed this question
Top Sakar Video Cameras Experts
 Mikey
Mikey
Mark Schmit
Mark Schmit
Are you a Sakar Video Camera Expert? Answer questions, earn points and help others
