Question about Uniden GMR 2638-2CK Two Way Radio
What is the RF output power, in watts
The manual doesn't list RF output power in watts (or watt, or milli-watts) from antenna. I would believe the range better if I knew the RF output power. I'm guessing a watt, or less and probably a mile range, point to point on flat ground in the country. Does this sound about right?
    Top Expert:
  • Uniden Master
  • 43,014 Answers
Probably 500 milliwatts.
Posted on Dec 26, 2013
2 Suggested Answers
  • 26 Answers
SOURCE: bearly 2 watts
Most cb's are eazy to open and tune. There are many sites that will give you the info. With a little time and brain power its eazy
or send it to a tec. If you need a tec. Ill do the align & tune cheep. www.herzjoe3@gmail.com
Posted on Aug 15, 2012
Cobra 142 very low rf output
Check your antenna, cable and all connectors. It is common for power to fluctuate if you have any short anywhere in the radio to antenna system. Do not test your radio without an antenna attached or what is called a "dummy load", you may fry your transmitter. Do not trust cheap cables that are pre assembled, I've had many bad out of the box.
John L.
Jan 22, 2014 | Cobra Radio Communications
Transceiver signal interference
The FT-840 uses a die-cast RF power amp with thermally switched fan to ensure full power output (up to 100 watts). The digitally synthesized local signals ensure clean, low-noise transmitter output on all HF amateur band. There might be no AC line interference. it has strong Rf output. any AC line intersect does not affect its radio performance. Check and adjust RF power so to maintain proper output. some times more RF power generated at the output may cause interference. adjust Rf power..Even some unfiltered Noise getting the other end of the end may calso cause interference. Check for any Ripple voltages present at the output. Contact authorised service station for further Rectification. thank you shanth
Dec 23, 2007 | Computers & Internet
Can you turn the rf gain pod up for better receiving
Yes you can turn up VR pot inside to recieve max level but will cause noise to be max too. I don't rightfully remember which one does it but I'll refer you to Defcom cb radio mods for a spec sheet
or Snakedoctors cb radio mods google site. Go to these radio mods sites on Google search and type in radio model. It will tell you what Vr inside to turn up RX of RF gain. Turn up modulation and written instruction if you are handy with solder gun how to change a resistor or cap to make it more sensitive recieve. How to replace final stage and resistors to 1/2 watt size for 6 more watts output and spread coils 1/8 inch apart like a comb for 100% microphone loudness or swing output. say 3 watts to 40 watts output. More windshield wiper swing in meter makes loud voice and extends range with Power final boost. Most people prefer to keep a mobile at around 11 watts swing to 45 watts.(but on generic radio meter will show 2 to 5 watts-its not accurate just a cheap indicator you are forward swing). Even though factory says 4 watts FCC hogwash. They come tuned from Cobra with 11 watts to 14-22 watts.Cobra really peaks them babies so competition doesn't beat them out like new louder radios made by Galaxy 55. Even though law says blah blah (corporations bend it)sales pitch Galaxy very heated with Cobra on the game(rich can do what they want)Galaxy is 20 watts factory with big promise to 40 watts dual finals. So Cobra updated and said "screw it we will break the law too" Now Cobra is loud as ever and offering their own super mod versions and dual final radios with 45 to 65 watts output with ranges on SSB & USB of 1500 miles on a strong good outdoor antenna.
Feb 15, 2013 | Cobra 29 LTD CB Radio
Icom ic 7600 rf issue
it is just because your cable is loose, try it after tightning it up
Jun 05, 2012 | Icom IC-7600 HF/6 Transceiver
On a kenwood ts-700a, is there a output power adjustment and where is it
Hi Joe,
If you're putting out 7 watts of RF power, you shouldn't need more to hit a repeater within 15 miles of your location, however, if there are no repeaters within range, then you must be in a rural location.
If this is so, then unless there is a repeater within reasonable range, you're not going to have much luck no mater the RF power your radio put out.
The more RF power your radio chuffs out, the shorter the battery life can be expected, 7 watts is enough to drain the battery quickly as it is.
If on the other hand this is a base set, I doubt it, then with a properly installed out door antenna, you should be making contacts with ease on 7 watts, depending on location as I've stated.
I hope this has answered your query.
Cheers,
Peter
Dec 09, 2011 | Kenwood Radio Communications
Receives very well- other radios can barely hear me-I have a short mag base antenna
The rule is the taller the antenna the better the reception and power output. Of course it is not always convenient to mount a 102" whip.
  • 4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
  • 4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
  • 4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5-inch antenna.
You did not mention the signal on their meter and how close they are. This may be a modulation issue. Wattage increases can go unnoticed volume wise but small modulation increase can make dramatic changes in volume to the receiving radio. Check that your dynamike or mike gain control is turned up clockwies increases it. The radio itself may need the modulation increased internally. If you have a powermike with adjustments on back it may be way to low. Hope this was of some help
Sep 01, 2011 | Cobra Radio Communications
I have spotty reception on a handheld CB and was wondering if there is a testing procedure I can use to check the antenna and radio. I have a multimeter. It's a radio shack handheld with weather bands...
The antenna is your problem not much gain. Height is everything tx and rx. Although it would not compare to a conventional cb size negates performance. Seeing is believing in this case hearing get adapter to connect to standard coax of antenna. (PL259) to BNC Coax Adapter Radio Shack sells them. And dont ask or buy any radios there. They are hardly the radioshack of choice anymore.
  • If you put 4 watts into a four-foot antenna, you will get the same power out of that antenna as if you were putting 2 watts into a 102-inch whip.
  • If you put 4 watts into a 3-foot antenna you will get the same power out as if you were putting about 1.5 watts into a 102-inch whip.
  • If you put 4 watts into a 7.5 inch antenna on a hand held CB, it would put out as much power as a third of a watt into a 102-whip.
  • If you put 4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
  • If you put 4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
  • If you put 4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5 antenna.
May 21, 2011 | Cobra HH 38 WX 40-Channels Handheld CB...
Do we need an amplifier to connect home theater yamaha nsc150/e105 with TV, DVD, PC.plz explain
Yes, you need an amplifier, since the "levels" of the sound-output from each device (TV, CD-player, cassette-player, Sony mini-disk player, turntable) are not sufficient to physically move the "cones" inside your speakers, to push air around, to produce sounds.
You need "watts" of power to push air, while the devices produce milli-watts (watts/1000) of power.
Also, the amplifier is also a "decoder", electronically processing the input to produce "5-channel" (left, front, right, back-left, back-right) surround-sound output.
Sep 30, 2010 | Audio Players & Recorders
Won't work more than ten feet
Hello jacknichols,
This means that you have an RF output problem. What you need to do is connect the antenna jack to a power output meter (with antenna loading) and measure the power out put when the mic is keyed. The power readfing you should be expecting is 4 watts (Peak Envelope Power) PEP.
I believe that you will read a lot less. If this is the case you will have to get a schematic of your CB radio and using a multimeter measure the voltages around the RF power output section of your radio and the sections leading to the output stage. This is assuming that you have a background in electronics. If not, I would suggest that you take your CB to a repair shop to have them find the problem and repair it.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 22, 2009 | Cobra Radio Communications
Uniden GMR 2638-2CK Two Way Radio Logo
78 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
