How tohooh up dcb091 cha roger to power
How do I connect the dcb091 to a power source
Power steering and brakes dont work are they connected somehow and how would i fix this problem
Hello cindygariepy: My name is Roger and I will help you. Yes they are connected. The truck uses a brake system called Hydra-Boost. There is no vacuum booster like the cars use. Hydro-boost brakes use the power steering system as a source of power assist for the brakes. You need to check to make sure the fan belt is still on the engine. Should the belt brake you will loose power steering and brakes. Next check to make sure the power steering has fluid. If you have a leak in the power steering system and the system is extremely low you will loose steering and brakes. Generally when the system is low you hear a noisy growl when turning the steering wheel. These are the usual problems that occur when you loose both the power steering and brakes at the same time. There is one other part that could cause the condition . That would be a hydro-boost failure. If it fails there would be a lot of fluid leaking at the driver side of the vehicle in front of the driver seat outside on the ground. Power steering fluid is a clear oil. Should you need further help please just ask. Thank You for using Fix Ya. Roger
Nov 20, 2010 | 2002 GMC Safari
CHA?
I found this answer on the Nikon web site.
3) Camera displays “CHA” in top LCD. The camera has detected an invalid partition type or is not working properly. Reformatting the memory card may allow it to be used. If an approved memory card causes the camera to display the "CHA" indicator contact the memory cards manufacturer for assistance.
Please note that the default disk format used in Windows XP is FAT32 and if a card is formatted with this setting on an XP system, a D1 series camera will report "CHA". Reformat the card as "FAT" to use in the D1 series camera.
Jul 11, 2009 | Nikon D70s Body Only Digital Camera
Can't see anything in LCS display
problem on ur lcd fpc that connecting camera to lcd that u want to chaing .if u cant chaing try to contact me my no.00971503853766 in u.a.e i have a service center
Jul 04, 2009 | Sony DCR-HC30E MiniDV Camcorder
I'm using rogers as my ISP. my rogers modem is connected to symantec gateway security 360 switch which is connected to D-link switch. i am connected to the symantec switch, and have internet connection,...
Hummm
it may be a pretty simple fix.
Connect the modem from rogers to the WAN port not to the switch port of the symantec gateway
connect the DLink switch to a switch port on the switch part of the getway and both of you should be able to get an internal IP
Apr 13, 2009 | Computers & Internet
Manual removal of cd magazine
Seems to me an error of the installers, just go back and ask them to remove the magazine properly.
Aug 08, 2008 | Alpine CHA-1214 12-Disc CD Changer
35 people viewed this question
 Grubhead
Grubhead
