Question about Panasonic KX-P3626 Matrix Printer
Kx-p 3626 all lights flashing beep sound - Panasonic KX-P3626 Matrix Printer
How can i set up speed dial?
Registration Register the handset to a KX-TG6700/KXTG6702 base unit. 1 Base unit: Press and hold {INTERCOM} until the IN USE indicator flashes. L After the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 2 Handset: Press {OK}, then wait until a beep sounds.
http://adcombhs.com/shopsite_sc/store/html/Panasonic_KXTGA670.pdf
Mar 07, 2011 | Panasonic KX-TGA101S Cordless Handset
KX-T3250B; the 5 red indicators on the upper right corner are flashing...
these 5 leds lights when phone is out of program. every phone should have his own indicator showing (when handset is off) his position in chain of phones. to make them stop flashing do following:
1. push and hold "PROGRAME" button until "MUTE" indicator lights (you'll hear beep sound).
2. push one "1" to "5" button on numeric keyboard depending on telephone's position in chain (must be unique).
3. push "MEMORY" button.
Now when you pickup handset only one indicator should light.
sorry, my English is not perfect :-(
Feb 04, 2011 | Panasonic Lands Phones
Phone keeps saying move closer to base
The handset may have unregistered from the phone. The instructions to reregister it are in the manual, but I'll list them here for you.
1. On the handset, press MENU 001
2. On the base unit
For models KX-TG6021/KX-TG6022/KX-TG6023
Press and hold LOCATOR until the IN USE indicator flashes.
For models KX-TG6051/KX-TG6052/KX-TG6053/KX-TG6054
Press and hold LOCATOR/INTERCOM until the IN USE indicator
flashes.
must be completed within 1minute.
3. Press OK on the handset, then wait until a beep sounds.
4. Press OFF on the handset.
Aug 29, 2009 | Panasonic KX-TG6021 Cordless Phone
Panasonic KX-TGA711E
this sounds like you are either out of range of the base unit or your base station isnt plugged into the mains, ensure you have the base station plugged into the power and the phone line from the wall socket is plugged in, the base station controls all the handsets, if it isnt plugged in they wont work, good luck
Aug 05, 2009 | Panasonic KX-TG1033S Cordless Phone
How to program telephone numbers in memory?
Your phone (KX-TC911-B) can store up to 10 phone numbers. Numbers 0 - 10 are your memory stations.
1. Make sure the TALK indicator light is off.
2.Press Program. The TALK indicator light will start flashing.
3. Enter the phone number.
4. Press AUTO.
5. Press a memory station where you want to store a particular phone number.
6. You will hear a confirmation tone. 1 beep means the number has been successfully stored.
2 beeps mean, you entered the same number that has already been previously stored.
Click on the link if you would like to have a pdf copy of the manual/tutorials.
Jun 24, 2009 | Panasonic KX TC911B Cordless Phone
KX FM 131 มีคำว่า paper jummed
 I HAVE A BROTHER FAX MACHINE.  I CAN NOT HOOK UP TO MY FAXES GOING OUT
Feb 15, 2009 | Panasonic KX-FM131 Fax
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
indicator flashes.
LAfter the IN USE indicator starts
minute.
3 Handset:
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Handset lights up, but does not work, only beeps when you touch any key
first, hold down the "handset locator" button on the base, until the "charge" light flashes. then, hold down the flash/call waiting button until the LCD says "handset registering." if after about a minute it says "error!!!" then try again. that is what the instuctional booklet says. i have not done this successfully yet as i have the same problem, but this is apparently how you fix it.
Jun 11, 2007 | Panasonic KX-TG2313 Cordless Phone
Panasonic KX-P3626 Matrix Printer Logo
42 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
