Question about Progressive Suspension 86-99 YAMAHA 1100 Virago Front Fork Springs - Kit
Spits and pops in first and second gear 1100 yamaha virago 86
The timing needs adjusted in low gear, it pops and spits
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Progressive ... Master
  • 1,190 Answers
If timing is set correctly as you can sometimes see a mark or dab of paint from factory then have you cleaned the carb and fuel system ?
Posted on Jul 10, 2014
Virago 1100 wiring diagram
Hi, Ruben for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Virago 1100 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
YAMAHA VIRAGO 1100 WORKSHOP REPAIR MANUAL Download Manuals Technical $10
OEM parts for Yamaha
Yamaha Virago XV1100L Owner Manual
Jun 12, 2017 | Yamaha Motorcycles
How to test for a seized 1994 535 virago
Hi, Mjenkins remove the spark plugs and put the transmission in 2nd gear and try to roll over the engine for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha Virago XV535 1100 1981 1994 Service Manual
Yamaha XV 535 DX Virago Service Manual
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-16_110.pdf
Yamaha XV 535 Virago Low Bars 88
Dec 27, 2012 | 1994 Yamaha XV 535 Virago DX
Valve lash adjustments for a Yamaha Virago XV 1100
Hi, Paul for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://viragotech.com/newtech/Virago%20valve%20adjustment.htm
Check and adjust valves on the Virago 400
Yamaha Virago XV1100K Owner Manual
Jul 29, 2012 | Yamaha Motorcycles
1994 virago 1100. Starter spins but wont turnover motor.
Hi, Manuelverdin the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
https://www.viragohelp.com/virago-owners-clubvoc-archives/virago-starter-repair
Yamaha Virago Motorcycle Starter Bendix Explanation Fix Pt 1
Apr 25, 2012 | Yamaha Motorcycles
I have a2004 yamaha virago 250 it wont start on 1st gear but it will start on nuetral but it idles really low and after a wile it shuts of. help?
Hi, Duce420666 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Virago XV250 Choke and Idle Problem Premium fuel
Yamaha Virago 250 Idle Stall Issue
Yamaha XV250G Supplementary Service Manual
Yamaha VIRAGO XV250P Owner Manual
Apr 22, 2012 | Yamaha Virago 250 Motorcycles
1986 VMax is slipping out of first gear, what do I do ?
Hi, Anonymous and the usual suspects are:
1. Shifter pawl improperly adjusted.
2. Shifter drum improperly adjusted or damaged.
3. Shifter engaging parts/dogs badly worn or rounded.
4. Shifter forks bent.
5. Damaged gears.
Jumps out of First gear
86 Yamaha VMAX VS 86 Suzuki GXSR 1100
Yamaha Vmax VMX17C 2009 Service Manual
Yamaha VMAX VMX17 Owner Manual
Apr 16, 2012 | Yamaha V-Max Motorcycles
Yamaha 1986 virago 1100 stuck in 2nd gear
Hi, Driverusx and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ViragoTechForum com
http://www.xs11.com/forum/showthread.php?t=36512
http://service.tanga-moteurs.ro/data/yamaha_virago_535_700_1100.pdf
Aug 06, 2010 | 1986 Yamaha FJ 1100
Low idle - yamaha virago 535(1994)
Hi, Ramberry and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
http://viragotech.com/newtech/535%20runs%20for%20a%20while%20then%20dies%20(SOLVED).htm
Yamaha Virago 1100 Idle
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Jun 05, 2010 | 1994 Yamaha XV 535 Virago DX
HAVE A VIRAGO 1100 AND THE GEAR SHIFTER STICKS IN
hi,2 possible causes,1-if the bike has remote linkages to the gear shift,check that the shaft that the gear lever itself is pivoted on,is well lubricated and moves freely,they sometimes have a habit of filling  with road grime over time and this will cause them to stick or become quite heavy in operation,2-and this requires removal of the crankcase cover to repair,the return spring on the shift drum has lost its strength and needs replacing,i hope that it is the first option as that is easy to fix,the second option not quite so easy and a lot more expensive if you have to have it done in a shop..hope this helps...cheeers
Mar 26, 2010 | 1992 Yamaha XV 535 Virago DX
2002 yamaha vstar 1100 pops out of first gear
Hi, Gilegang and the usual suspects are:
5. Damaged gears.
Popping out of first gear
Yamaha XVS1100 Service Manual
YAMAHA XVS1100 Owner Manual
Feb 28, 2010 | 2002 Yamaha V Star 1100 Silverado
Progressive Suspension 86-99 YAMAHA 1100 Virago Front Fork Springs - Kit Logo
111 people viewed this question
Top Progressive Suspension Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Progressive Suspension Boating Expert? Answer questions, earn points and help others
