Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven burner won't stay lit
Oven burner lights but goes out after 30-45 secs. Relights itself after 10-15 secs over and over. Appears gas flow is being interrupted.
    Problem Solver:
  • 12 Answers
Often it is is easy is getting a welding tip cleaner or ven the end of a paperclip in a size that matches the holes on your gas burner. Simply gently push and pull the welding tip cleaner paper clip or even wire in any of the holes that appear blocked. I had the same problem with my burners. I found a paperclip that matched exactly the size of the holes on my burners I simply push the clip into the holes to clear them. Runs like new now.
Posted on Dec 26, 2013
SOURCE: gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Posted on Dec 14, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
SOURCE: Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Posted on Jun 08, 2009
  • 396 Answers
SOURCE: Gas oven Hotpoint RGA 720 I can't light the oven pilot
There is likely some kind of gas line blockage or valve problem. This is not a do-it-yourself fix. Call a repair person.
Posted on Oct 15, 2009
  • 221 Answers
SOURCE: The oven pilot does not light. The broiler will
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Posted on Jan 10, 2010
    Will not stay on will shut off
    Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
    forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
    Jun 20, 2012 - 2 posts - ‎1 author
    My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
    Feb 19, 2013
    Oven does not stay lit
    Jun 19, 2012
    Oven will ignite but will not stay lit
    Aug 3, 2010
    Gas Oven won't stay lit
    Mar 25, 2008
    More results from forum.appliancepartspros.com
    Jan 04, 2016 | Ovens
    Oven lights but then flame goes out as soon as I release the knob
    The flame sensor seems to be bad.
    When I light my pilot light, it stays on till I release the button ...
    askville.amazon.com > Home > Home Improvement
    Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
    Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
    Why won't burners stay on
    Alguien puede ayudarme con el diagrama electrico del horno imperial
    gracias
    Jun 20, 2013 | Imperial ICVD-1-H Turbo-Flow Gas Single...
    Pilot light won't stay on
    What is the model number of the unit?
    Nov 27, 2012 | Tappan Kitchen Ranges
    I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
    While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
    Jul 28, 2011 | Ovens
    I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
    Instructions
    1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
    2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
    3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
    4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
    5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
    Jan 26, 2011 | Ovens
    Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
    On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
    Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    52 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
     Fix Your Board
    Fix Your Board
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
