Question about Panasonic KX-P3626 Matrix Printer
Lights flashing error
Panasonic kx-p 3626 one beep and all lights blinking. everything looks normal and nothing is blocking the carriage's path.
4 Suggested Answers
SOURCE: PANASONIC KX-3696 - CARRIAGE AND
check your power supply, your board maybe damage..try 2 change your IC in board.
Posted on Nov 27, 2009
SOURCE: carriage error in my panasonic kx-flb802
can not make copy by scanner
Posted on Oct 06, 2010
  • 52 Answers
SOURCE: hi, my proplem when i make
You may have sent too many print jobs into the printer queue at one time. You can check that in the lower right hand corner of your screen. If you see the little printer icon, it means there are jobs in the queue. If that's the case, just right click on it, a list of print jobs will be shown. Just highlight each one, and right click, then select cancel printing. That should clear out any extraneous print jobs. Now, if your printer is doing that when you are only printing one job, I would recommend removing and reinstalling the printer drivers. That should fix the problem. Good luck!
Posted on Jan 24, 2011
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
6A81 Printer error has occurred
This error indicates that something is blocking the carriage from moving (the carriage is the part of the printer that holds the ink cartridges)
This can be from a piece of paper being caught in the carriage path, or a mechanical issue like a broken gear
First, sharply unplug the printer while it is powered on, then double check these instructions for removing all paper jams (click below):
Especially look inside the printer where the carriage moves back and forth to make sure nothing is jammed in there and is blocking the path:
Remove all paper from the paper feed and blow it out with compressed air a few times > With a flashlight look in the paper feed
Make sure there is no foreign object like a paper clip in there
While the printer is still off, press and hold the power button for 3 minutes > Load 1 sheet of paper into the paper tray
Finally, while holding down the stop/cancel button, plug the printer back in, and power on the printer if it doesn't do so automatically. Now see if the error is gone.
If not, please reply back and let me know, we'll take other steps to resolve the issue.
Aug 30, 2014 | Office Equipment & Supplies
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
I am getting a service error 5100.
There is something blocking the carriage from seating home. 5100 generally means there is either something in the paper path or an obstruction in the ink carriage path. Open the clamshell to look at the carriage path and make sure the cable connecting the carriage is not restricted.
Apr 19, 2009 | Canon PIXMA iP1600 Printer
PANASONIC KX-3696 - CARRIAGE AND PRINTHEAD NOT MOVING. ALL INDICATOR LIGHTS BLINKING
Jul 09, 2008 | Panasonic Office Equipment & Supplies
Panasonic tvs-100 voice mail beeping and flashes red power light four times
I'm having an issue with the same unit. But the blinking light is NOT on my phone it's the power light to the actual unit in my server room. It will flash 4 times and then stop. Flash 4 times again... I have looked through the manual to see what 4x power light means and I have found nothing!
Jun 21, 2008 | Lands Phones
LQ-2180 printer is Continues blinking front panel lights.
The LQ2180 blinking lights can be caused by paper jammed, printhead overheated, paper loaded not detected and cover unclosed. Try to check all this first, you may have a fragment of paper stick to the sensors, or broken sensor. If all of the light flashing try to check the carriage movement, move it side to side, but with power off condition. If the carriage movement not smooth or stuck, look for any foreign matters inside the carriage path that blocking the movement if not, try to lubricate the rail which hold the carriage. If this doesnt solve you, the machine require parts replacement.
Apr 14, 2008 | Epson LQ-2180 Dot Matrix Printer
Handset lights up, but does not work, only beeps when you touch any key
first, hold down the "handset locator" button on the base, until the "charge" light flashes. then, hold down the flash/call waiting button until the LCD says "handset registering." if after about a minute it says "error!!!" then try again. that is what the instuctional booklet says. i have not done this successfully yet as i have the same problem, but this is apparently how you fix it.
Jun 11, 2007 | Panasonic KX-TG2313 Cordless Phone
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Panasonic KX-P3626 Matrix Printer Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
