Question about Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7
Screen will not rotate
When rotating tablet from vertical to horizontal it will not.
    Sergeant:
  • 302 Answers
Go into settings and tick auto rotate
Posted on Dec 26, 2013
Please keep my screen from rotating on my ipad.
Swipe your finger up from the bottom of the screen so it displays the controls. The one at top right with a padlock in a circle with an arrow in the clockwise direction is the orientation lock. Tap it once to lock.
Jun 07, 2015 | GSI Wireless Mini Bluetooth Keyboard For...
My Kindle only shows the books horizontally on the screen. When I turn the Kindle, the words do not move into the vertical position.
There is probably a rotation screen lock in the settings if this is on the screen will not rotate when the tablet is turned to the desired position the option should be in the settings menu need more info to determine where in the settings it is at
Jan 24, 2015 | Tablets & eReaders
How go I rotate my tablet to vertical
1. Tap on the top right corner of the Home Screen to access the tablet > utilities.
2. Tap Settings > Screen.
3. Tap to deselect/select Auto-rotate screen.
Oct 19, 2014 | ASUS Eee Tablets & eReaders
Allwinner A20 dual core android tab screen want rotate
Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
Also, some tablets have a hardware (physical) switch on the side that locks rotation.
Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
Can only get the vertical view on screen. it will not turn to horizontal mode
Drag your finger down from the top to get the Quick Menu icons along to top of the screen.
Top LEFT of the Quick Menu is a Circle icon. Tap it to turn on/off the Screen rotation lock.
(If 1 finger does not work then use two fingers. You have turned on Accessibilty. Go to Settings / Accessibility to turn on/off)
Dec 23, 2013 | Amazon Kindle Fire HD
Hipstreet flare 2 9DTB7 8GB
Have you tried this:
1. Settings
2. Accessibility
3. check Auto-rotate screen
^_^
Dec 11, 2013 | Tablets & eReaders
Purchased an hp tablet last friday and did as the instructions said. I began using it saturday and noticed the image remains the same when I rotate from verical to landscape. read the instructions again...
To enable screen rotation, access the notification curtain by swiping down from the top of the screen. Touch the rotation icon, which looks like a lock circled by arrows. This should unlock
and allow the screen to remain static while the tablet is rotated
Dec 31, 2017 | HP Slate 7
My screen only shows in horizontal not vertical since the most current iOS7 update.
If this issue only happens in certain apps, then it's probably because the app has not been updated to support the different screen orientations.
Also check the General settings and make sure you have not set the lock setting that keeps the screen from rotating.
If all else fails, you should contact Apple support to have your device checked out.
Hope that helps!
Oct 28, 2013 | Apple iPad (16 GB) WiFi Tablet PC
IPad screen will not rotate. NOT locked, restart and reboot completed. Stuck in Vertical and running iOS version 6.1. Any solutions?
If u swipe from the bottom up, to get to the control center (or go to settings), is the orientation locked, or unlocked?
Jul 14, 2017 | Apple iPad (16 GB) WiFi Tablet PC
Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7 Logo
199 people viewed this question
Top Mach Speed Trio Tablets & eReaders Experts
Lawrence Oravetz
 Grubhead
Grubhead
micky dee
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
