Question about RIM BlackBerry Pearl 8120 Cellular Phone
My bb pearl wont cut on i kepp it in charge for 2 hours and nth all i could see was a battery sign and a dash help
    Sergeant:
  • 314 Answers
Upgrade your sw
Posted on Dec 26, 2013
5 Suggested Answers
SOURCE: Symbol that wont go away on a BB 8110 Pearl
there is a symbol above the time on my blackberry it says the number one and has a world symbol ??
Posted on Jan 26, 2009
Obertelli
  • 3006 Answers
SOURCE: BB BOLD9700 battery dies in a few hours after full
In that case you either have a faulty phone causing a high battery drain, a faulty battery (most likely) or a faulty charger. Even if you have BlueTooth and WiFi activated and use the phone a lot like I do, you should get at least a whole day out of it (I get a day and a half and I'm a very heavy user).
You probably guessed that already, but the point is that none of them are DIY fixes and all of them will still be fully under warranty as the Bold 9700 was only released to market in September '09.
In this case, the answer is simple, return your phone and charger for a refund/exchange. The supplier may suggest just swapping the phone at first, so if that fails they'll then change the battery/charger. Remember to remove the sim and also the micro SD card first, as the replacement handset will not have one: you may also be told to retain the rear cover for the same reason.
Make sure that you perform a full back up via BlackBerry Desktop Manager as you'll then be able to transfer your data straight onto the replacement handset. Afterwards, fully data wipe the phone for security. This can be done in BB Desktop or you can do it under the security tab in the settings menu. Alternatively, if you have a phone password then just enter it incorrectly a few times (ten attempts is the default) and the phone will then prompt you to type in "blackberry" before wiping itself. Note that these security tips only apply if your phone was a private purchase, if your phone has been supplied by your employer then follow their directions instead as they may have the corporate Enterprise Edition of the BB Operating System installed which does some things a little differently.
I hope that this has helped, if so then please rate my answer.
Posted on Feb 19, 2010
SOURCE: BB Bold 9000 wont turn on - red light is flashing
I' really sorry to tell you, but looks like your phone's logic board is out of work! It happened if mine BB 9000 two moths after the warranty expired! Took to a technician and I was told to replace the logic board! It was happen like this (http://www.youtube.com/watch?v=MGSRQb1Qb1Y) before it get out of order forever! Hope I have helped you! Just to you to know I tried just about everything that is on the net, and nothing worked!
Posted on Jul 06, 2010
nainamainaka
  • 380 Answers
SOURCE: bb bold wont charge
Welcome to the BlackBerry Support Community Forums.
Have you tried plugging the BlackBerry is different outlets or tried a different USB cord?
Does the BlackBerry show a charging symbol or is the LED flashing red or green?
I look forward to your reply.
Posted on Feb 24, 2012
Bb pearl wont turn on and has a sign with a dash pls help me
need software update
better go to bb service centre nearby
Dec 26, 2013 | RIM BlackBerry Bold 9700 Smartphone
My BB pearl wont charge.
You should take it to the store cuz probably one of the wires in it is mal functioning
Apr 08, 2010 | RIM BlackBerry Pearl 8100
Have a dark screen but apparently BB is working as I get vibration (but no ring) when either a call or text is coming in. Tried battery reseating and sim card reseating. Checked battery and have good 3.7v...
i bought new phone today it balckberry 8120 pearl and i cant turn it on i recharge the battery like 5 hour and all i can see is a flesh red light that al
Apr 02, 2010 | RIM BlackBerry Pearl 8100
OK, my bb went to radio use turned off, when i plugged it in to charge, the screen went blank but stayed lit. I took the battery and SD card out along with the sim card replacing only the battery. when i...
go to www.blackberry.com and download the desktop manager for your phone and service provider and reinstall the software. if it is an unlocked phone you need to navigate to the common files/rim and delete the vender file first.
Nov 30, 2009 | RIM BlackBerry Pearl 8100
My bb pearl it`s flashing 3 times stop then 2 times i can`t start my bb i can`t upload anything my computer dosn`t see my phone.what can be done to fix my bb?
Perform a hard reset on the BlackBerry smartphone. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
If the battery is working, download the latest BlackBerry Device Software and install it using the application loader tool in BlackBerry Desktop Manager.
Nov 21, 2009 | RIM BlackBerry Pearl 8100
New BB 8130 Pearl phn and new battery and its been charging
Remove the battery, then remove the Memory card and Sim card (if you have a sim card). Then replace battery. Try this. If this does not work, while off try connecting the device to your pc, through bb desktop software. If the device STILL does not turn on or your pc does not recognize it, you may have a hardware problem.
Link To BB Desktop software: Click Me
Hope this helps
Sep 26, 2009 | RIM BlackBerry Pearl 8100
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. A new battery was tried and the problem still exists.
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in to cell store.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. The icon stays on with the backlight until the battery dies, A new battery was tried and problem...
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Blackberry 8310
4. Take in.
Aug 09, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blacberry pearl niot charging
I have a new blackberry pearl, have had it two weeks and today it will not charge no matter which charger I use so I don't know what the deal is.
Jun 10, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Pearl 8120 Cellular Phone Logo
21 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
