Question about Yamaha RX-V1600 Receiver
I've tried to reset the input and I/o sources, I've tried to rename the dtv input all to no avail. I still get great amp sound from every other source not dtv. Should I reset the amp? It's not in the Manuel
Have you checked to make sure the TV connection is from the correct TV output? The TV is not on mute? Recheck all connections. The amp obviously works ok.
Posted on Dec 26, 2013
SOURCE: hdmi connections
Hi, If you are trying to use HDMI video, and want to give autdio input separately, that can be done in many ways. In fact I am giving HDMI video from my HTPC at DTV inoput and audio over SPDIF (optical). In the menu there is an inout select option. You need to go into DTV, then select which audio to use. You can then choose whoch input port for audio is being used with DTV.
I have issues with HDMI input as well, but those have to do with refresh rate of 60 Hz and 1080i.
Posted on Jan 02, 2008
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: DTV Cable No Sound
Check if DTV/CBL is set receive COAXIAL or OPTICAL inputs. Good luck
Posted on Nov 23, 2008
SOURCE: Remap digital audio on Yamaha HTR-6130
Actually I found in the sound menu on the receiver that there is an input source setting changer for the 3 digital audio inputs. Also you can change the names of the other inputs to match your components needs.
Good work Yamaha.
Posted on Jan 12, 2009
SOURCE: Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Posted on Feb 07, 2009
Sep 24, 2014 | Yamaha RXV367 5.1-Channel Black Digital...
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Aug 25, 2011 | Onkyo TX-NR905 Receiver
May 31, 2011 | Yamaha Rx-v565 Receiver
Mar 25, 2011 | Audio Players & Recorders
Nov 25, 2010 | Kenwood VR-6050 Receiver
Oct 25, 2009 | RCA 27F534T TV
Oct 22, 2008 | RCA P46924 46" Rear Projection Television
Jun 30, 2008 | Marantz Audio Players & Recorders
Jun 11, 2008 | Televison & Video
Apr 05, 2014 | Yamaha RX-V1600 Receiver
Apr 27, 2013 | Yamaha RX-V1600 Receiver
113 people viewed this question
