I just got an asusu memo pad for Christmas wich was yesturday it was running low on battery to I pressed to the lock button and went to get my charger when I came back I pressed the lock button but it wouldnt turn on so I though it was already dead I left it charging for a while and when I tried turning it back on it wouldbt turn on since then it hasent turned on
  • 7,993 Answers
Do yourself a favor and read the manual, at least the quick setup part.
Posted on Dec 26, 2013
SOURCE: Iriver PMP-120 will not turn on
i wos camping when my pmp 120 stoped workin so i smashd it up there and then that seemd to work lol
Posted on Jul 22, 2007
  • 51 Answers
SOURCE: ipod not turning on/not recharging
Have you tried holding down the menu button and the middle circle button?
first place your ipos somewhere flat and press down the circle button and the menu button,make sure your not touching any other part of the click wheel.hold them down for about 5 seconds untill the apple logo appears.then let go,and it should be back to normal.you can use this procedure any time that it freezes or stops working.Hope fully that should fix your problem.if not i suggest you get it repaired under your warrenty.
Good Luck.
Regards.
Sophie
Posted on Feb 14, 2008
SOURCE: I cant get my coby mp3 to charge?
That's because u didn't plugged in your computer. Your computer have to be turned on..
Posted on Dec 27, 2008
  • 5 Answers
SOURCE: Zune won't turn on or charge
I have had A zune before the charger that comes with it only works for a few charges you will have to get a differant chager for it, it worked for me
Posted on Jan 04, 2009
SOURCE: My Sansa Fuze Wont Turn On or Charge
Hold down the power button for 30 secconds to a minute, then let go and turn it on again as per normal. This is a built-in reset function.
It seems to happen for me when certain mp3's are played, i think they might be corrupt and the palyer doesnt like them, and so crashes.
Hope this helps!
-DaALC
Posted on Jul 19, 2009
Screen locked and alignment wrong
To restart, press and hold the on button on the upper right of the device. Select 'Restart' from pop-up menu.
Not sure if you can recalibrate your screen.
If all else fails, perhaps you can try hard reset:
http://hard-resets.com/hard-reset-asus-memo-pad-hd7/
Try if you can avoid wiping data by selecting option not to wipe.
Apr 21, 2014 | ASUS MeMO Pad HD 7
Bypass screen lock asus MeMO pad
check your setting memo pad... uncheck automatic update...
Mar 13, 2014 | ASUS MeMo Pad Smart 10
Frozen asus memo pad
the memeory if full wont doload any apps,internal memery
Feb 03, 2014 | ASUS Memo Pad ME172V
Asus Memo Pad 7 will not turn on
It did work for a while? I've had occasions where I plugged in my tablet but it didn't charge because the plug wasn't seated correctly. Also I discovered it only worked with one of the cables I have even though any mini USB cable will fit. Do you have another cable you can try to plug into the unit
Jan 03, 2014 | ASUS MeMO Pad HD 7
I just got an Asus memo pad for Christmas which was yesterday I had low battery so I pressed the locked button and went to get my charger When I came back to plug it in my memo pad wouldn't turn on I...
Make sure you have pressed the on / off button for long enough. I have to hold mine in for about 5 seconds before the screen starts. Hope that's all it is, cheers.
Dec 26, 2013 | Cell Phones
Trying to factory restore a asus memo pad
It not power on or it have a paswoard problem ? if is paswoard remove it with yoo pc and this program mobogenie instal it in you pc then conect and instal you memo pad in the pc then go to folders ask the paawoard archive edit it and ready clear all paswoard in to you memo pad vote please
Dec 07, 2013 | ASUS MeMO Pad HD 7
Will not turn on
check the voly out in you vcd adapter if this exist go to open you pad and rebulding soldering the conector volt in and then ready you pad work again please vote
Dec 03, 2013 | ASUS MeMO Pad HD 7
I forget my pattern lock?so how will get return my password
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Nov 02, 2013 | ASUS MeMo Pad Smart 10
How to play ps2 games on pc
there is the software called pcsx2 software which allow to play ps2 cds on pc
Dec 18, 2007 | Computers & Internet
19 people viewed this question
 Grubhead
Grubhead
