SOURCE: W850i red light prob
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
SOURCE: phone will not turn on unless it's plugged in
The battery has a short in it and if you replace it The phone should probubly work.
SOURCE: I went swimming and forgot my EnV3 was in my
As the mobile is wet the circuit board inside the mobile will be fully wet.Due to this the connections between the circuits get connected(short circuited) and the mobile may behave in such a manner that it should not behave. Never put the wet mobile in charger even though it is dry and working properly.There may be water logs present in the mobile circuit which may be dangerous to the person who is using the mobile.It may lead to electric shock.
Take the mobile to the authorized dealer of your make and they will remove the water log from the mobile circuit board and it will be fine .I recommend you not to do this by yourself.
Thank You
Testimonial: "I really found that helpful, I thought I was going to have to cough up $50 to get a replacement, but I'm guessing I'll have to pay a small fee. Thanks"
