Question about Amana ARS2661B Side by Side Refrigerator
Ammana diagrams wiring
Not cooling or freezing
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
Tip
I have a french door Ammana with this problem and I am looking for the capacitor...
Many people have had problems with their refrigerator compressors not starting and wonder what may be the problem. Many times the problem can be traced to the start components. The start relay and the start capacitor work together to help the compressor get started. By giving it a short extra shot of higher voltage current, it gives the compressor the kick to get it turning up to speed.
The capacitor is the long round tube on the top of the box that houses the compressor terminals and the start relay.
The start relay is pushed right onto the compressor terminals C and R. It also has two wires that go up to the start capacitor.
The relay can be removed by just pulling out on it away from the compressor off of the pins.
If your refrigerator compressor is not starting, you can change the start components easily, to see if they are the problem. Usually you will have about a 50-50 chance of the compressor working again by changing these parts.
If you are looking for the configuration of the compressor terminals, here is a picture of the terminal cover that shows which terminals are where.
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
on Dec 27, 2010 | Refrigerators
U-clr2060s-41 will not go into clean or freeze. Shows power on board.
Sure sounds like a relay problem on the main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the icemaker.
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns Clr2060s41 Parts
Jun 12, 2014 | Refrigerators
1999 cadilac deville cooling fan wiring diagram
There are a couple of diagrams and a good discussion of this at this link: http://www.2carpros.com/questions/1999-cadillac-deville-cooling-fans-relays - Read in particular the info from expert "FactoryJack" about the 3rd comment down. Good luck!
Apr 26, 2014 | 1A Auto Parts 1999 Cadillac Deville Sedan...
Need belt diagram
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Scroll down on the above page the Ammana is the second or third one on the list.
May 14, 2011 | Amana Dryers
My Ammana Freezer is not defrosting. I need to figure out if it is the Defrost Thermostat Defrost Timer or the heating element. What should I do first?
in most cases its the defrost element as the other units last much longer unless the fan has become jammed this happens when people toss meat hard against the back wall if you know how to do polaity test using a multimeter do test on defrost element its not a thermistate as new age frezzers dont use them they use timers and plastic channels to curculate cool air
good luck need more addvice email me
Jun 25, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore model 596.52673202 refrigerator not cooling or freezing
the defrost should be controlled by a timer every 10 hrs or so,it is usually in the bottom of the fridge by the compressor,it has a small motor that turns the timer,they burn out
Jul 21, 2009 | Kenmore 53642 / 53644 Side by Side...
I think it's a motor problem
Your problem is the compressor (motor) start relay. They are inexpensive and availible locally from a refrigeration parts supplier. Check the wiring diagram on the back of your unit for installation help.
Ray
Jan 05, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Amanna auger not turning
the best i will tell call service it not good for you to check
Dec 04, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Amana ARS2661B Side by Side Refrigerator Logo
24 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
