Question about Boss R1100M 1100 Watt Mono Power Amplifier with 8 Gauge Amp Wire Kit
Where is reset on r1100 m monoblock amp
Does not power up
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
Is it safe 2 install these subs 2 a 2000 watt power acustic amp and if so how do I wire them for a 1 ohm stable load
It looks like you have the Power Acoustik OVN1-2000D Mono Block 2000 Watt amp.
Monoblocks all feed speakers normally and cannot be bridged. So hookup your speakers
as normally with + on the amp to + on the speaker and same with the -.
Now for the speakers. I dont know too many Kicker speakers that are 1 ohm but the
monoblock wont care. It will feed the 8,4,2 or 1 ohm speakers the same power. You just may
get less response from the higher ohm speakers-less Bump Bump. You could wire your speakers
in series to get a lower ohm load (2-4ohm speakers in series gives the amp a 2 ohm load) and get
better response. Here is a site that answers many electrical and speaker questions.
See # 57 on the right hand pane. Tells you exactly what will do best. Good luck.
Electronics Answers Made Easy
Apr 27, 2011 | Kicker Car Audio & Video
JL A1800 Amp Not Switching On?!?
did you test for power at the amp, you should have 12 volts when the deck is on at the amp on the power and pto terminals. Also check and maybe reground the amp
Jun 05, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Car amplifier
HI PAL BUY MONOBLOCK AMP TO DRIVE UR SUB TRY GET ROCKFORD FOSGATE, KICKER,BMBOSCHMANN,OR INFINITY
Jun 03, 2009 | ElectroVoice EVM10DLX Car Subwoofer
Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
2 ohm dvc and monoblock sub amp
Yes. When you run two-two ohm subs to a monoblock amp its on the same channel meaning there ran parallel, and that makes it one ohm and most mono-blocks won't read one ohm. Are you popping fuses in the amp?
Apr 02, 2008 | Audio Players & Recorders
Boss R1100M 1100 Watt Mono Power Amplifier with 8 Gauge Amp Wire Kit Logo
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
