Question about Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2
Cannot connect to wifi irulu cannot connect to IP address
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
I have the digiland tablet dl700d(c) and I can't connect to Wi-Fi I called Wi-Fi support they can't help because the mac address keeps changing is anyone else having this problem and what do I do
Hi
I find your question very interesting, and also your WiFi support comment, because in 18 years of IT consultancy and troubleshooting I have never come across a changing mac address.
The mac address is
"a unique identifier assigned to network interfaces for communications on the physical network segment. MAC addresses are used as a network address for most IEEE 802 network technologies, including Ethernet and WiFi."
The emphasis here is on "unique" and all network adaptors I have come across - ethernet or WiFi have had a fixed mac address. Are you sure they didn't mean IP address, as this is supplied by the router/access point via a DHCP server, and can change according to the access requirements of the router/access point.
If you go here:
MAC address Wikipedia the free encyclopedia
you can learn a lot more about mac addresses.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Tablets & eReaders
I am having trouble connecting to wifi the password is correct but saying authentication problem what can i do
check the Security type (viz WEP , WPA etc), the accesspoint seucrity type and client end security type must match.
Dec 20, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
How to change irulu ax922 tablet battery replacement
The most Irulu tablets have 2 small cover screws on each side, pop the cover unscrew it and open with careful. the battery is connected inside its a square white plastic cover connected to the motherboard . Hope this help.
Mar 20, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Wifi shows it is connected but i can't get on
+Hi, I know how frustrating this issue can be. I finally shut every thing down...the android, the wifi connection and the modem. When I turned the android back on, and of course, the modem had reset, so I then reentered the wifi settings on the android. I'ts been working ever since. Good luck.
Mar 16, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Adding ip address
You cannot add it manually...you can switch OFF and ON the device and again try the internet source like Wifi etc...If it gets connected..visit Ip-details.com and get the Ip address.
Jan 06, 2014 | Tablets & eReaders
My son has a irulu table model number AK305 and it wont turn on at all
am trying to connect with internet my device (irulu ak 305) but it didn't connect
Jan 03, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
4.1 jellybean keeps searching for IP address. Will not connect. All apple products connect fine
This is the result of a bug in Android 4.1, you'll have to manually assign an IP address to your Android device.
Instructions on how to do this are available here:
http://www.trickswindows.com/2011/12/fix-obtaining-ip-address-android-wifi.html
Dec 15, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
My galaxy tablet cannot detect our wifi connection. it always says disabled and scanning, obtaining IP address but will not connect. ive turn of/off the unit and entered the passkey several times but still...
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
Jan 02, 2011 | Samsung Galaxy Tab Tablet PC
Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2 Logo
55 people viewed this question
Top Irulu Tablets & eReaders Experts
john smith
gbob59
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
