Question about Big toys Usa MotoTec 24V Mini Quad Battery Operated Ride On - Blue
Mototec mini won't start
Mototec mini 24v is fully charged. When I turn the ingnition, nothing happens. Why wont it start?
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
I have a 95 honda civic ex,wont start.ran fine yesterday,wont start this morning.battery is fully charged,new cap and rotor.would do u think might b my problem
if it wont turn over 1st check the ground s on the car and the battery 1st. your battery can be fully charged and the car will not start even over night this can happen. then look at the starter. Note: if you have over 109K on the car and the timing belt has never been replaced you will need to have this checked as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tom_db3a51ff0ca57f20
Aug 16, 2014 | Cars & Trucks
Optura 60 cannot be turned on
Whether you think the battery is fully charged or not this sounds like a defective battery problem. Have the battery checked.
May 05, 2017 | Canon Optura 60 Mini DV Digital Camcorder
2000 Pontiac Sunfire won't start
Try checking the oil, the low oil sensor will disable the ignition
May 29, 2017 | 2000 Pontiac Sunfire
Big toys Usa MotoTec 24V Mini Quad Battery Operated Ride On - Blue Logo
75 people viewed this question
Top Big toys Usa Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Big toys Usa Toy Expert? Answer questions, earn points and help others
