Question about Kenmore Refrigerators
The freezer works fine, but the top compartment of the kenmore elite sidebysidefridge will not get cold. why? how do i fix this?
The refrigerator was not cool, but the freezer was working. I looked on the internet and it sounded like the evap fan wasn't working - not moving air from the freezer to the frig. I got the part # from our manual and we went out and bought it for $43. It is behind the back wall of the bottom freezer. the freezer works fine, but the top compartment of - image.tiff
image.tiff Here is what it looks like behind the wall. The motor that was bad is the white rectangle that is being held up by the black clip.
This is the new motor which looks differenthe freezer works fine, but the top compartment of - image.tiffsupposed to be the replacement.imathe freezer works fine, but the top compartment of - image.tifflass=
Here is the new one installed.image.tiff It works!!!!!! It wasn't that hard to do and saved us a lot of money.
Posted on May 01, 2010
Kenmore elite trio 596 73503201
This happened on my side-by-side. There is a damper at the inside top of the refrigerator compartment that was failing to open to allow cold air in. I took the cover off and propped open the damper while I ordered the part and waited for it to arrive. Problem solved and hope to keep it running another few years.
Nov 13, 2013 | Kenmore Refrigerators
Kenmore Elite refrigerator model # 106.74206400: freezer compartment working fine, refrigerator compartment about 20 degrees too cold. Found a method for running a diagnostic: 1 and 2 passed, 5 failed. ...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 12, 2011 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer
It is either a defrost timer or limit switch, That's the little clip on device located on top of one of your freezer coils. This is the most common item to die on many newer refrigerators. It is also pretty inexpensive, and easy to get from Sears or 1stsource parts. In rare cases your defrost heater may go bad, but I haven't had to replace one in a long while.
Mar 09, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
May 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
69 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
