Question about Encore (ENP832-TX-PC) (ENP832TXPC) Wireless Adapter
Speed I hooked up the Encore wireless usb adapter it works but is slower than net zero dial up. Could it be settings or a weak signal?
    Problem Solver:
Make sure you are connected to YOUR wifi network. You may have connected to a more distant & slower router.
Posted on May 17, 2009
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
I can't make my ENUWI-SG USB work!
Some old laptops only have USB1 ports. The G adapter may be a #2 or #3 USB device. If the laptop is a ONE, the connection is too slow to adapt to a modern speed of G or N. You may have to use direct wire from the modem to the laptop in order to communicate with the internet.
Feb 04, 2018 | Encore WL ADAPTER |ENUWI-SG USB 2.0...
Wireless adapter connects at 54mb but drops to 1mb w/any dataload
Usually, a device will renegotiate a slower speed to compensate for interference. slower speeds are sometimes the most reliable. Its possible to change your wifi channels and try to get one that has less interference, and maintain a stronger signal. You might also want to ensure that any cordless phones in your area are NOT on the same frequency range as your router, because as soon as "Old Great Aunt Mildred" calls you or your neighbor, your wifi goes bye bye.
Aug 31, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I just installed d-link wbr-1310. I am getting 1/4 the speed using wireless. Are there any setting I change to resolve this.
Wireless connections are running on a slower speed by definition.
A wired connection with this router sets the maximum speed at 100 Mbps.
A wireless signal in a 802.11b network has a maximum speed of 11 Mbps, and a 802.11g network has a maximum speed of 54 Mbps.
These numbers are theoretical numbers and never achieved in reality. (like a Toyota Prius makes 60mpg...)
So depending on your wireless network adapter and how your setup physically looks like (distance to the router, interference with telephones, microwaves etc.) it is absolutely possible that you wireless speed is considerably slower than your wired connection.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 20, 2009 | Computers & Internet
DWA-160 adapter going slower than dial-up
nek arep baner yah mas kuwe ku sing madan larang lan bermerek terkenal...nek ora ngerti brarti kowe bodo nemen alias gatek
Aug 11, 2009 | Computers & Internet
Get a stronger signal
You are pushing your luck at 70ft. You can probably get booster ariels for your router that can boost the output signal for approx £10.
Dec 13, 2008 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Good Signal,Good Mbps, Slow Internet Connection?
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
let me know how it works out.
Nov 30, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Good Signal, Good Speed, Slow Internet?
Try plugging the computer straight to the router.If all is well the adapter may need a firmware or driver update.Or your adapter may be experiencing some type of heat problem or failingRICHARDM69
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
My wireless Encore adapter is a 802.11g
If you are using Windows XP, In the lower right hand side there is a blinking tray icon that looks like a computer with waves coming from it, double click it and you will see "signal strength" with green bars. If your wireless adapter is internal, you may have to move the wireless router until you get a better signal on your computer. Try putting it somewhere up high with no large metal or concrete objects between it and your computer. If your adapter is external USB, move it around until the signal improves and try to secure it in that position. Hope this helps.
Jun 26, 2008 | Encore Computers & Internet
Enuwi-g2 problems
What operating system are you using, Win XP?
Go to the control panel - look at Network Connection, click on properties on your USB adapter, click on Internet Protocol (TCP/IP), then Properties, make sure Obtain an IP address automatically is selected.
Also make sure your USB adapter settings (SSID, WEP/WAP etc) matches your Access Point settings.
Mar 04, 2008 | Encore Wireless Ethernet Network Adapter
Encore (ENP832-TX-PC) (ENP832TXPC) Wireless Adapter Logo
57 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
