Question about GE WPRB8050D Top Load Washer
5kh61kw2516hs clutch is broken
Replacing clutch on toyota rav4
first off make sure that it is a clutch problem
there are too often reports that the diy or mechanic has replaced the clutch when the problem was a broken/ jamming clutch cable or faulty clutch master cylinder
the same symptoms of a slipping clutch, not disengaging to select gears , shuddering etc are indicative of clutch control problems ___ cable or hydraulic failures or broken engine mounts
a lot cheaper to check the outside bits first
Apr 15, 2017 | Toyota Cars & Trucks
265 Massey Ferguson clutch won't release
Broken fork, broken shoulder on throwout bearing. Bearing seized on transmission shaft, broken pivot
Jan 31, 2016 | Toys
How to replace broken clutch cable
Escapes do not have clutch cables. They have a hydraulic clutch, which in my opinion is easier to work on. My 2001Escape did something similar a few years ago. It wouldn't disengage the clutch enough to get it into gear. It had a bad clutch slave cylinder.
Check under the hood and see if you have a leak of brake/clutch fluid (same reservoir)
If not then you either have a bad clutch master cylinder or slave cylinder most likely.
Jul 08, 2014 | 2001 Ford Escape
Clutch handle is loose no tension on harley 1340 5 speed cable isn't broken
Hi Don, you have a broken clutch cable and it needs to be replaced and for more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
How to replace clutch cable on Harley Davidson 88 CU Dyna Super glide FXD
How To Properly Adjust The Clutch Clutch Cable Harley Davidson
Harley Davidson Manuals Mark Workshop
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 25, 2012 | Motorcycles
Clutch peddal went straight to floor and wont come up again
probably have a leak in the system somewhere fill it up with the proper fluid push pedel slowly while someone inspects the clutch lines lines and slave cylinder, and master cylinder to see where its coming from, there not too many parts in the clutch system. the slave sylinder may be internal which would make it harder to inspect but not inpossible
Feb 02, 2011 | 2004 Chrysler Voyager
R reg, 1.6i zetec escort estate finesse, clutch peddle constantly deppresed, suspect peddle mechanism not clutch!! how can i reset clutch peddle???
You might have a broken cable or the clutch pedal is broken at the top.Unless it a hydraulic clutch and the fluid level is low.
Oct 09, 2010 | 1998 Ford Escort
Replacing a broken clutch lever on a 2005 VFR Interceptor
thats about it,,,all you need to do if fit the new one but let the clutch adjuster off first so you can fit the cable to the leaver
Jul 15, 2010 | 2005 Honda VFR 800
Kawasaki ninja zx9r clutch problem
On your bike there are two clutch parts that can wear and cause this problem. The broken spring should be replaced but is not causing the problem. Check the bottom of the clutch release shaft #13102. The end of the shaft may be broken, bent or severely worn. The part the shaft engages with is the clutch rod #46102. It could be bent, broken or severely worn. This part is inside the clutch hub. Just remove the five springs and then the outer cover plate and the rod should be accessible.
Jul 18, 2009 | 1998 kawasaki ZX-9R Ninja
GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Oct 03, 2008 | Washing Machines
GE WPRB8050D Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
