Question about Nextbook Premium 7 Capacitive Touch Android Tablet 7" Touch Screen
After turning my tablet on it says "Please place on tablet in level" I've reset it to factory setting numerous times and still does this
  • Crystal Richards
    Crystal Richards Jan 27, 2014
    did you ever fix this. my nephew has the same problem
How to Factory reset genesis tablet
Hello there.
A hard reset will fix your dilemma. To do a hard reset first turn your phone off. Press the volume keys+ power button at the same time for about 5-10 seconds, an android logo should bring up. You are now on the system recovery menu, scroll through the options using the volume keys. you will find a prompt asking you if you want to reset factory settings, choose YES and your device should boot up like the first time it was bought. Be warned though, doing a factory reset will delete all your files/ installed apps.
Read more with Pictures and Video- How to Factory reset genesis tablet
Feb 12, 2016 | Tablets & eReaders
How do I reset google password? Tablet want accept password and I am locked out.
Reset all settings on the browser on the tablet and try again, confirm password by using another computer or tablet.
Dec 03, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How do I unlock my trio tablet! The code is a pattern and the tablet doesnt give me an option to retrieve the pattern or even reset it. Please help! Thx Kat
Some tablets will prompt you to reset after you have tried and failed entering the correct password a certain number of times. You can try this, it could work too.
Jun 26, 2014 | Tablets & eReaders
Factory reset Kocaso M760
Try this before you do a factory reset by loading the firmware again.
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Support Troubleshooting Guide
May 23, 2014 | Kocaso M760W 1.2GHz 4GB 7 Capacitive...
My apps continuously stop and I have factory reset numerous times to no avail on my apex ap7s118 plz help me with this problem
Hi.. by going to task manager u should have to clear the previous opened apps.. so that apps are running in background.. so u have to close it every app.. or
Update the Definitions for OS.. then the problem will solve..
Apr 06, 2014 | Tablets & eReaders
Reset button
1. Go to settings
2. Scroll down to Backup & Reset.
3.Go to Personal Data
4. Choose Factory data reset.
Be aware that you will lose all unsaved settings. I've tried doing it numerous times to try to get the non working camera to reset and also to get the G-sensor to work. Not fixed doing this.
Mar 16, 2014 | Hannspree SN10T1 101 Tablet
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
Do not have the pin to unlock my toshiba excite 10 tablet what is the code
Factory reset is the only answer;
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
Jan 08, 2018 | Toshiba Tablet. Excite 10.1 in. Android...
Nextbook Premium 7 Capacitive Touch Android Tablet 7" Touch Screen Logo
67 people viewed this question
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
