Trying to determine if this is mold
I have a few pictures of a basement wall that was only partially covered with drywall, and the exposed insulation has black spots on it. Trying to determine if this mold or not. I'd like to send a few pictures if someone would be willing to take a look. Thank yo u
  • 9,633 Answers
Put some bleach on the spots. If they turn brown or disappear, then it is mold.
Posted on Jan 05, 2014
4 Suggested Answers
  • 148 Answers
SOURCE: water draining from window air conditioner runs
your problem is definately the pitch of the unit
Posted on May 18, 2009
samtoler
  • 666 Answers
SOURCE: Can I recess baseboard heat registers into
That is not safe bro
Posted on Jun 17, 2010
pendletonhea
  • 144 Answers
SOURCE: black mold inside unit, fan
It sounds like you know the problem and the sollution is to clean it. these system require rutine cleanings every 6 months because they have condensation always in the pan
Posted on Oct 14, 2011
I am fixing a closet in my home. It is part of an exterior wall and creates a lot of coldness in the house. How can I insulate this wall better? My kid is freezing at night she says. <a href
If you have enough room behind the stud wall install 1" rigid foam tape seams and then use the thickest possible roxsul insulation to fill the studs. Or axe the foam and install 6mil plastic on warm side of the wall after insulating tape all seams when done.
Jan 30, 2015 | Cam Spray Pressure Washer Foamer...
Can I tape between a popcorn ceiling and a smooth drywall wall?
By beading, are you referring to drywall tape? If this is cracked and you want to repair the tape, I suggest you use a nice cove mold to cover up the lose tape. Otherwise you'll need to remove the old tape, smooth out the popcorn ceiling area, re-tape the corning then feather it in, then texture the ceiling again. The trip is much easier to do. It's cleaner, quicker and really would look nice.
Will it stick? yes but unless you want to keep the same look, I opt for the cove mold.
Nov 14, 2014 | Drywall
Condensation dripping from ceiling in all electric home with no basement
The wall of the daughter's bedroom is NOT insulated. Moisture from normal activities (showering and cooking) within the house are causing the realtive humidity to be above 50%. When that moisture enters the wall or ceiling, the temperature drops below the dewpoint and condenses out. The moisture that condenses makes a nice environment for the growth of black mold which is highly toxic. The mold will spread by airborne spores. If you have return air ducts for your HVAC system in the room, the spores might be dispersed throughout the entire house, depending on how good you HVAC filter is. Note that if you have a swamp cooler on the roof, it could be leaking water through the ceiling and causing the problem.
You need to immediately move you daughter to another room and remediate the situation -- tear out all the drywall and anything that is damp or has signs of visible mold. Get the humidity in ther house below 50% with a dehumidifier. I would recommend the Winix 50-pint model (refer to link below). This will condition 1500 square feet, which is a lot, but you will need one on each floor.
Amazon com Home Kitchen
Jan 29, 2014 | Kirby Shampooer Shampoo Hose G3 Ultimate...
How do I repair a large hole in my drywalled wall in my living room that is right beside the door frame?
If you live near a Home Depot or Lowes they sell partial sheets of drywall. Cut a square slightly larger than the damaged area from the new drywall. Trace this around the damaged area and then cut out the damaged area with a key hole saw or sawzaw or if you don't have those just your utility knife. You can probably buy all the tools and materials for a lot less than hiring someone. Since you said the hole is next to a door you shouldn't have to worry about electrical wires, but just in case, take a flashlight and look into the hole before you cut to make sure. Now you should have a hole the size and shape of the new piece you cut. The area against the door is against studs and you'll have to just keep cutting with your knife until you get through to the wood. Now, on the other side of the hole across from the door take a piece of scrap wood and put it inside the hole and press it against the inside of the wall so half the scrap wood is behind the wall and the other half is exposed in the hole. While you're holding the scrap wood you'll need to screw 1 1/4" drywall screws through the existing drywall and into the scrap wood. The scrap wood should now be tight against the back of the drywall and partially exposed to resemble the stud on the other side by the door jamb. Now you have backing for your patch. Place the patch you cut earlier in the hole and screw it in place. A screw gun or drill with #2 philips head screw tip will make this job easier. The screws should be counter sunk just slightly so the heads don't rip the paper. If you do rip the paper you'll need to put in another screw near that one or else you'll have problems later, especially near a door. Now finish the hole with joint compound. You can buy this at most hardware stores in a one gallon bucket. You'll need a role of drywall tape as well. I recommend the fiberglass mesh tape for ease. Also you'll need a taping 6" taping knife and a tray.
Fill the joint compound tray half way and mix it around with your knife until smooth. Take the fiberglass tape and stick it to the wall around the patch to cover where you cut. Spread a thick layer of joint compound over the fiberglass tape and then gently wipe it all off with one or two strokes. Repeat this until all the tape is covered with a thin layer of "mud" (joint compound). Make sure all the screw holes get filled too. Let this dry for several hours, maybe overnight. Put the excess mud back in the bucket and clean your tools. When the first coat is dry take your 6" taping knife and scrape away any blobs of mud that you left behind from the first coat and then apply a second coat. You may need a third coat. Sand the joint compound until smooth tapering the edges to the paper. Again, be careful not to sand the paper too much, you don't want to go through. If you have smooth walls, you're in luck, now just paint. If you have textured walls then you have more work. you can get spray texture in an aerosol can at the hardware store. Read the instructions on the can and practice on the left over drywall from your patch. Note: you'll never make a perfect match with this aerosol texture but you can get it close. The only way to get a perfect match is to use a compressor and and special spray gun for joint compound and it takes some practice. You can rent these things in most towns if you're very particular. Good luck
Aug 09, 2013 | Tools & Hardware - Others
Should i use the same drywall in the bathroom as in the rest of the house?
I recommend using MR (Moisture Resistant) drywall for the bathroom, and possibly for the basement if there are moisture issues. It is not much more expensive, and it can save you a big headache later
Jan 16, 2013 | Drywall
I have noticed blue mold in my basement coming from behind the area that has wood paneling, but also around the entire edge of the floor even where the walls are concrete (both interior and exterior...
This mold is from dampness in the basement.
Often this is a result of no vapor barrier installed when the insulation is put into the walls. Moisture is allowed to seep through the walls and gets into anything, even concrete.
The other problem may be from a lack of weeping tiles outside the house.
When the contractor formed the foundation walls, he was supposed to install weeping tiles to keep moisture out from outside.
Most older houses don't have this, and I'm seeing it more and more.
I would advise contacting a general contractor and getting some advice from them. You may have to have weeping tiles installed, which consists of tearing up the ground around the foundation to do so.
Then you may have to remove the flooring and wall panels as well as the drywall to install a vapor barrier.
Good luck.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Sep 22, 2011 | Computers & Internet
Want to put lamipanel in old shower unit. Tiles have been removed exposing a brick wall. What should I use to cut the lamipanel, fix to the wall and seal joining edges. Can lamipanel be used on the cement...
you can use a pocket knife to cut it ,after you measured where it needs to be cut.set a level over it as a guide then roll the pocket knife along the level a few times. ( the nife you use to cut drywall).to seal it use a very good silicone its cost around $8.each.you can also use for the joints a vinyl molding that comes for that laminatepanel to put it together.good luck,any problem feel free to ask about it again.
May 30, 2011 | Home
I would like remove old vinyl shower wall and install a tile wall. but do i have to remove the drywall also? I'm keeping the shower base.
if the sheetrock is in good shape you should not have any problems. If you are worried about mold and mildew, you might want to change out the drywall with either green coat or yellow coat- these are mold and mildew resistant
Nov 04, 2009 | Home
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
