Question about Protocol Predator SB 3.5-Channel Remote-Controlled Helicopter
Its spins around in circles - Protocol Predator SB 3.5-Channel Remote-Controlled Helicopter
THE TAIL MOTOR IS NOT WORKING PROPERLY OR NOT AT ALL. YOU MAY NEED TO REPLACE IT
Posted on Jan 12, 2014
Oven knob spins in circles no control
There should be a metal spring cip ring around the spindle of the knob which keeps it tight around the spindle on the switch. Sounds like its snapped. Compare it with one that works, they should just pull off and push back on, but with a little bit of resistance.
Nov 26, 2013 | Estate Kitchen Ranges
Galaxy Tab 2 10.1 I can obtain new e-mail headers using Yahoo Mail but trying to get the e-mail body just provides a 'circling arrow' sign
Theres no such thing as new email headers, only "full" email headers. The circling arrow means you're getting it stuck screwing around. (i.e. your confusing your browser), try using firefox, or chrome, or slimbrowser, etc.
spin
Oct 12, 2013 | Yahoo Mail
Won't scroll down but will scroll up, have tried turning it upside down & rolling the ball around but it didn't help
Have you tried cleaning out the inside where the ball sits? If you flip your mouse upside down you should see a circle around the ball that should have "open" and "close" arrows. Spin the circle towards open and once it stops spinning flip it over -- the circle and the ball should fall right out. Take a look at the 2 straight bars that sit on top of the mouse ball -- one is for horizontal movement, the other for vertical. Most likely, there is a buildup of dust and debris on them (it will probably look like a grey spot that covers the center of the bars). Remove this debris with your finger-nails (as they will not scratch the bars themselves) and then wipe them with some rubbing alcohol on a paper towel. Once the bars are clean, drop the ball back in, and put the circular cover back on (don't forget to lock it in place by spinning it to "close".
This SHOULD resolve your issue. If it does not, there may be a problem with your mouse's movement sensors ... which would most likely mean that you should buy a new mouse (they are pretty inexpensive these days). If you have to buy a new one, I recommend grabbing an optical mouse -- it has no moving parts and will prevent this problem in the future.
Jun 07, 2011 | Apple Mighty MA086LL/A Mouse
I have the Magellan 1440, all I get is where it
  1. Get a clear view of the sky and then turn off the unit and then power on again.
  2. Once the unit is on and you see the street display tap on the signal icon on the screen.
  3. You will see a half globe with horizontal signal color orange and wait for at least 5 full green signal and then close that page.
  4. Once your in the sreet display you will see tsignal strength on the screen.
Feb 12, 2010 | Magellan RoadMate 1440 Car GPS Receiver
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
I have just instaled my harman kardon ks200 and there appears to be a problem? i can hear the cd spinning louder when listerning to track 1 than i can when listerning to track 10 eg. should there be a...
* Tech Stuff *
Audio CDs do not spin at a constant rate. They are designed to be read (for music) at a "constant linear velocity" of about 1.25 meters per second. The data is written in a tight spiral starting at the inside of the CD. The CD spins the fastest when reading the inside tracks and slows down as it reads towards the outside edge. Imagine circles on the CD surface. The inside ones would be smaller than the outside ones, of course. So, if you are reading evenly-spaced bits on the lines of those circles, you would need to read fewer outside circles per second than the small inside circles.
* Basic Issue *
When the player is reading Track 1 the CD is spinning at about 500 rpm. During the last tracks of a (full) CD it only needs to spin at about 200 rpm. It doesn't work the other way around for compatibility reasons.
* More Info *
This is why you are experiencing the difference in mechanical noise at different tracks. It doesn't necessarily reflect a defect, but understandably, a consumer would prefer a quieter system, which does differ between manufacturers and models (I couldn't specs for a KS200 HK device) Yet, if the noise is substantial, it may very well be indicative of a problem, e.g. something stuck in the drive and being whipped around in a circle at high speed. I wouldn't say this is particularly likely.
* Possible Help *
What would normally mitigate this issue is not getting too close to the player while listening. Normally having the primary listening position several few feet away (across the room) would suffice to minimize noise heard from fans and spooling CDs.
May 14, 2008 | Televison & Video
Protocol Predator SB 3.5-Channel Remote-Controlled Helicopter Logo
200 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
gmduvall
Are you a Protocol Toy Expert? Answer questions, earn points and help others
