Question about 8.8" Mustang 28-Spline High Performance Series Diff
What oil go in a xy falcon 1971 9 inces diff - 8.8" Mustang 28-Spline High Performance Series Diff
    Problem Solver:
  • 14 Answers
Either 80w90 mineral. Or 75w90 synthetic. Will work is this a possi trac rear end ? If it is you will have to add anti slip additive
Posted on Dec 26, 2013
05 BF Falcon taken out 6 bolts at both diff and gearbox end. Can't get the tail shaft out diff end. Removed cap and is full of grease but wont come out, bashed the hell out of it but to no avail.
The shaft is balanced so the bolts needs to go back through EXACTLY the same holes they came out of. That's both shaft AND diff. Not lining up could shake something important to pieces. SO MARK IT BEFORE REMOVAL.
There is no tail shaft at the Diff end. It is mounted flush to the flange plate. Knocking it left and right should free it.
Jan 18, 2018 | Cars & Trucks
Hi I have a ford falcon au 2001 it keeps trying to stall when driving below 60km an hour and when I turn corners any ideas on what it maybe
could ve your diff trying to lock up.
have you checked the oil colour and level?
maybe you could have your gearbox oil and filters replaced and check for swarf in the oil.
Jan 12, 2018 | Ford Cars & Trucks
How do i fit a rear wing to a 1971 xy gt falcon
place masking tape on the area of the bootlid where the pillars/risers of the(i assume you mean)spoiler are going to be screwed,ensuring you have access to the underside where the bolts are to be fitted.You may have to juggle the fitment to get the optimum balance of accessibility(for the bolts)& cosmetics(how it looks)-leave the trailing edge overhanging the boot just until you think it looks good and the access thru the inner bootlid frame is sound(you can drill access holes thru the frame if you need to & seal/bung those holes when ur done.
right now place the spoiler & draw around the base risers onto masking tape-remove spoiler,measure carefully the bolt holes & transfer measurements onto the bootlid-lightly centre pop those marks(only after you've triple-checked your marks) & drill the holes-i start with a 2mm & work up to the final bore-allow a bit bigger than the bolts,so 8mm bolts drill at 8.5 or even 9mm;you can drill thru the frame too if u need to but just make sure you don't foul the boot aperture rubber or the guard channel gutter. Now if your measurings good you should be able to fit ur spoiler using a good sealer between bootlid/spoiler & a waterproof washer on the bolthead side-hope this is helpful,i've fitted many in my time-just take ur time & think as u go-you'll be sweet
Jan 18, 2015 | Cars & Trucks
I have 1971 xy falcon and compliance plate lists trim as "T". Cannot find what colour this represents
Probably a Tan colour in the range of all Tan colours. Even if the car had been carefully resprayed, the true colour lies behind the compliance plate because the plate is added after the factory spray paints the car, then it is never removed. If you can remove the plate you will probably see the originally factory paint of a Tan colour. Do not forget to replace the plate with rivets. Cheers bro.
Dec 28, 2014 | Cars & Trucks
How do I simplify expression xy^2/xy.
xy^2/xy....... I am taking this as not being (xy)^2/xy.
So divide the top and bottom line both by xy. You get y/1 = y
Sep 29, 2014 | Mathsoft StudyWorks! Middle School Deluxe...
I would like to know what type and weight of oils to use in my 04 Excursion. Its a 4WD Eddie Bauer. I am attempting to get all specs so that I may just get under it one weekend and change all the fluids...
Ok, you use 15W 40 for engine oil rated for diesels for most conditions If it's going to be below -20, you should use 5W 40 full synthetic for diesel. It takes 5 quarts, so buy 6. For your transmission model 4R100 and transfer case, it takes 6.4 quarts Dexron III or equivalent transmission oil. Your transfer case takes the same oil. It takes 17 quarts for a total refill, which means draining the torque converter as well. I don't have the specs handy here for the diffs, but your automotive supplier should be able to tell you. It always pays to buy a little extra, too. The other thing that is REALLY important to change, especially with a diesel, is your engine coolant. The best place to buy your coolant is right from Ford and get their additive. They will tell you exactly how much you need. It is critical to the life of your diesel engine to get the coolant that's designed for it, and don't let anyone tell you anything different. I have replace many liners that were pinholed from cavitation from using the wrong coolant. Front and rear diffs: XY-90-GL in the front (SAE 90) in the front, 3.8 pints, XY-75W140-QL (synthetic)in the rear 6.5-6.9 pints, plus 2 XL-3 4oz modifiers in the rear in you have a limited slip. You can also check your powersteering fluid to make sure it looks clean and doesn't smell burnt. Have a fun weekend!
Feb 19, 2011 | 2004 Ford Excursion
Hi my brake pedel in my 1971 xy ute is very hard and does not like stopping what could be the problem .
I am not very familiar with this vehicle but the place I would suggest you start looking is the vacuum line to the brake booster. Make sure it is connected and is not cracked or split anywhere.
You could also run the engine and use a hose like a stethoscope, just put one end up to your ear, and the other all around the booster to see if you can hear any vacuum leaks.
If this doesn't help get back to me and I will try to help you some more.
Jan 06, 2011 | Ford Five Hundred Cars & Trucks
How much engine oil goes in a 1971 Honda CB 350?
2.1 quarts of 10w40 motor oil. NEVER use synthetic oils.
Sep 09, 2010 | 1971 Honda CB 100
How do i replace diff oil in my au falcon
Ther is a plug on the differential
Sep 16, 2009 | 1983 Ford Fairmont
Adjust valves on 1971 chevy 350
either the intake is sucking oil from the bottom of the manifold, very common, other is the rings are gone, also very common,lighterr oil usage is a valve stem seal issue. the valves are hydraulic and unless u are installing new rocker arms require no adjustment.
Feb 17, 2009 | 2000 Chevrolet Blazer
8.8" Mustang 28-Spline High Performance Series Diff Logo
65 people viewed this question
Top Auburn Gear Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Auburn Gear Vehicle Part and Accessory Expert? Answer questions, earn points and help others
