Question about Cell Phones
LGM5659 setting have stopped
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
My Doro phone keeps saying unfortunately your settings as stopped. What can I do please?
Method:1
Goto settings-apps-all-setting and settings-apps-all-setting storage
click clear data and then click force stop.
Method:2
Goto settings-apps-all-launcher
click clear data option and then your launcher is restarted.
finally once reboot your android the error is fixed.
In a more explained way: Go to settings, find application manager, go to all, find settings, press clear data, close it, then again to to settings find application manager go to all find settings, and click force stop.
Mar 11, 2017 | Doro Cell Phones
After power cut need to reset vcr clock on philips vr750 but have lost the manual
Hi
To set the clock:
Manual Clock Setting
1Press the VCR button, then press the MENU button.
2 Press the PLAY [UP]or STOP [DOWN] button to select INITIAL
SET UP, then press the FF /OK button.
3Press the PLAY [UP] or STOP [DOWN] button to select CLOCK,
then press the FF
/OK button
4Press the PLAY [UP] or STOP {DOWN] button repeatedly to set
the TIME. Every time you press the PLAY [UP] or STOP [DOWN] button,
the time changes in one-minute increments. If you press and hold
the PLAY {UP] or STOP [DOWN]9 button, the time changes in 30-minute
increments
5Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
the DATE (month and day). Every time you press the PLAY
[UP] or STOP [DOWN] button, the day changes in one-day increments. If
you press and hold the PLAY [UP] or STOP [DOWN] button, the day
changes in 15-day increments.
When the month and day are correct, press the FF /OK
button
6Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
the YEAR. When the year is correct, press the FF /OK
button. The day of the week will appear automatically
7Press the FF /OK button once again to skip "AUTO
CLOCK" and go to "D.S.T." (Daylight Savings Time).
Press the PLAY [UP] or STOP [DOWN] button to set D.S.T. to ON
or OFF. If AUTO CLOCK is OFF, you may set D.S.T. to ON or
OFF only
8Press the EXIT/STATUS button
Jul 13, 2011 | Philips Televison & Video
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
How do i set the date on a locman ref 487?
  • To set the date you pull out the winding knob to the first stop and turn it either clockwise or counter clockwise to set the date. The second stop, or the stop furthest from the body sets the time.
Mar 07, 2010 | Locman LOC487MOPFBK wristwatch
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Number of Rings, I want to reduce the number of rings
Press and hold STOP/SET button for two seconds to access the set-up menu. Press STOP/SET to continue. Press STOP/SET over and over until the Machine says "Rings to Answer". To set the rings to answer just press NEXT or PREVIOUS to select how many rings you would like. Toll Saver option answers after 5 rings unless you already have a message, in that case it will answer after 2 rings. After you hear the option you like, Press STOP/SET button to store it. Now just press STOP/SET over and over until you get to the end of options, it should beep when you get there. Once you get to the end the machine will announce all the settings for review.
Aug 13, 2009 | GE 29878GE1 Digital Answering Machine
Lost directions for ProSpirit Fast Wrap
press the mode button untill you get to the setting where the seconds are flashing.hit the reset button to menuver through the hours, minutes, days, and months.
Jun 16, 2009 | Watches
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
Cell Phones Logo
235 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
