Question about Genius HS-04SU Headset
My computer won't recognize genious hs-05A headset
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
My A4tech HS-7P headset is not working?
Hi, I'm having a problem about the headset HS-7P model of A4tech........ my problem is after 30 mins or 1 hour the headset was disable from the control panel of my computer what is the best to do to troubleshot of my headset? Thanks! please answer!
Feb 03, 2012 | A4tech PK Computers & Internet
Looking for windows 7 drivers for the Genius hs-500x headset
The Genius hs-500x headset simply plugs into your headphone and microphone jacks on your computer.
The microphone jack is red and the headphone jack is green.
The audio settings are changed within the communication application you are using like skype or gaming.
Aug 03, 2011 | Computers & Internet
Where can i find genius headset hs-04u driver? the CD doesn't work anymore
pardon my grammat.. see the web at http://geniusnet.com/geniusOnline/online.portal?_nfpb=true&supportPortlet_actionOverride=%2Fportlets%2FsupportArea%2FproductCatalog%2FfindByModel&_windowLabel=supportPortlet&_pageLabel=supportPage&test=portlet-action download and exec
miy good bye,,,
Marcos Conttreras.
Mail: Marcos-C@latinmail.com
Sep 30, 2009 | Genius HS-04U Headset
My microphone will not work, and my computer won't recognize!
Common problem with this headset.
In short, the wiring for the mic in the left earpiece is quite shoddy, and over time will be worn away by changing the mic position or come loose with minimal effort.
Have had a over a dozen of these fail in our internet cafe due to this issue after a couple of months use.
May 31, 2009 | Genius HS-04SU Headset
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
HS-23 Not Being Recognized by Phone
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Dec 01, 2007 | Nokia HS-23 Headset
Genius HS-04SU Headset Logo
Top Genius Radio Communications Experts
Tom Chichester
Clive
Clive
Are you a Genius Radio Communication Expert? Answer questions, earn points and help others
