Question about Nakamichi Audio Players & Recorders
Hooking up Nakamichi  BT05 Bluetooth Speaker - Nakamichi Audio Players & Recorders
2 Suggested Answers
blues4evr
  • 181 Answers
SOURCE: my nakamichi paws Bluetooth speaker turns on and then turns off . I have charged it with isn male to male cable but still keeps turning off
I have a BT pen that I have to delete from Devices sometimes so that it reconnect.
Check your Devices-Bluetooth, delete and let it pair up again, just like when it was install the first time.
It also may be a power management issue where the computer turns off connections to save power. You can turn that feature off.
See if that works.
Posted on Mar 27, 2016
My Nakamichi shockwave Bluetooth speaker comes on,but can barely hear it?
Did it get wet? If it got wet unplug it and let it dry (use a hair dryer on medium heat). Did you try it on another device? You also said reset but did you reinstall the driver software? Do you have another sound program running?
Dec 08, 2016 | The Audio Players & Recorders
Would like info on indicator lights meaning. Would like a breakdown procedure for battery replacement.
Try Nakamichi,com user manual/parts battery replacement. Here is a link that has that info.Nakamichi High Com II Please comment helpful if it is, helpful.
Jan 17, 2015 | Nakamichi Audio Players & Recorders
Where could I find a manual telling care and indicator light meanings for the Nakamichi BT 04 portable Bluetooth Bar Speaker.
Yes, you can replace the battery yourself. The case is most likely heat sealed so you will have to be careful taking it apart so you can glue it back together.
My Nakamichi soundbar won't hook up with my seiki tv I've plugged it into both L R ports but no sound. The bluetooth works just fine so it's not the soundbar
Make sure the two ports that you've connected to are outputs. Then disable the built in TV speaker and adjust output volume on the TV.
Dec 25, 2014 | Televison & Video
Nakamichi mini speaker has crackling noise as soon it is switched on
check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Audio Players & Recorders
Value of the power supply block capacitors in nakamichi re 10 receiver
calculate & fix - circuit volt*1.41= ***
flow - 220v * 1.41 =310.volt above capacitor.
May 28, 2012 | Nakamichi RE-10 Receiver
I just installed a Dell BT05 wireless adapter in my Dell Vostro 1500 and I have a ViewSonic Viewpad 7. I am trying to get them to connect via Bluetooth. The computer is asking for a code and I cannot seem...
Have you tried 1234 or 0000. These are common codes for bluetooth devices that don't give a random code.
If that doesn't work, try connecting the tablet to the laptop instead of the other way around.
Jan 21, 2018 | ViewSonic Computers & Internet
Nakamichi SS-5 humming noise at stand-by nmode
Nakamichi service center in New Delhi. call +91 9871371720
Jun 26, 2009 | Nakamichi SoundSpace 5 Shelf System
392 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
