Question about Toshiba Satellite Computers & Internet
Clicking sound wont turn on
Will not turn on at all, there is an intermittant clicking sound
    Top Expert:
  • Toshiba Master
  • 22,705 Answers
What make and model?
Posted on Dec 25, 2013
Testimonial: "toshiba satellite laptop C855-S5352."
  • 4 more comments
  • Keith Collison
    Keith Collison Dec 26, 2013
    plugged it in and the power light comes on. also the caps lock light blinks when it tries to start.
  • JonSnell Electronic
    JonSnell Electronic Dec 26, 2013
    There is a known issue with hp, toshiba and that range from a few years ago. Due to suffocation, the GPU gets too hot and unsolders itself. That causes all kinds of issues especially boot and VGA issues.
    If the clicking sound is coming from the hard drive, I think that could be the problem. Replace the hard drive and reinstall the OS. Copy your data over, if you haven't gotan up you haven't got an up to date backup.
  • Keith Collison
    this is a brand new laptop , nothing stored on it yet. the clicking is coming from the dvd drive. i just removed it and tried turning on but no good. I have removed most items now 1 by 1 and tried but nothing.keep getting dame thing. im afraid this thing is toast and yet new. biggest problem is i bought awhile ago and warraty ran out october
    If you temove the dvd drive, does the clicking stop and will it boot?
    If it works without a dvd drive, look on flea bay and search for the drive, they are very innexpensive.
My2002 sierra with a4.8 with a good battery, all my dash lights and cd player come on but the truck doesnt turn over right away sometimes it takes 5-10 minutes 2 start of repetitively turning key over
battrey is good but truck makes no sound and wont even click
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusbattrey is good but truck makes no sound and wont even click ... Asked by Jennifer May 15, 2013 at 03:21 PM about the 2002 ... quite obviously the amps aren't getting through~ how do you know the battery is "good". the date ... If it turns over your power and starter are good but the ignition circuit ... Used GMC Sierra 1500".Missing: a4
Intermittant Failure to Start : Chevrolet Silverado 1500 ...
repairpal.com > Problems > Chevrolet > Silverado 1500
first start engine turns over alot. 2000 Chevrolet Silverado 1500. Hard start. When starting my truck it often takes two or three attempts. It kicks over but does not ...Missing: a4
Chevy Silverado and GMC Sierra Starting Problems - Car Forums at ...
forums.edmunds.com > Chevrolet > Chevrolet Silverado 1500
Oct 20, 2008 - 30 posts - ‎19 authors
i got a 2001 silverado 1500 and it wont start it turns over and fires and .... Put the key in and the truck barely starts due to the battery being weak. .... If it was really 8, the lights would be dim? .... I have a 2002 GMC Sierra 4.3L 2WD. ... I bled the fuel filter looking for air, but good fuel came out the top bleede ...Missing: a4
Jan 01, 2016 | 2002 GMC Sierra 1500
Car randomly wont turn on/bogs down and dies
Could be a bad engine ground connection. There should be a cable connected between the engine block and the frame. If this is loose, it could cause intermittent failure of your ignition and your starter to operate properly.
Sep 28, 2015 | 2003 Mazda Protege
What could be the problem with LCD tv?
There is still a power leak and intermittent short on the circuit board. You did not get the entire board fixed. Check all diodes for polarity and openings. Test resistance values and look for any other unstable components.
May 09, 2014 | Televison & Video
Radio shack noaa desk scanners squelch sound unit wont scan
If the squelch is on, there can't be a loud noise. Either the sqelch is completely off or you are not tuned to a station. NOAA broadcasts are continuous, not intermittent
Oct 01, 2012 | Radio Shack Radio Communications
I have a 1978 MGB..wont turn over..clicking sound..is that the starter motor?
Make sure your cables to the starter and battery are tight and clean. A good jump will test if the battery is the problem. Starters can become intermittent before they go totally bad. Corrosion on cables and connectors can interfere with voltage delivery. Start system needs really good battery connections and just having lights is not a good enough indication. A strong click and no spin usually means the connectors in the solenoid are not engaging or the brushes in the armature are worn out. A whimpy click usually means a bad connection or low battery.
Jul 25, 2012 | MG B Cars & Trucks
Turn key and just get a click battery charged and all lights work just bought and started first two times took it home and next morning it wont start
Sounds like you may have a dead spot in the windings of your starter, replace the starter and that should fix your intermittent starting problems.....
Dec 07, 2010 | 1991 Geo Prizm
Intermittent clicking of turn signal
these vehicles have a very common problem that allows the flasher to click even though the signal is not on.. this is an internal directional switch problem and can either be taken apart and cleaned or replaced to correct the problem...
Jun 13, 2009 | 2003 Pontiac Grand Am
Switch clicking on start up wont start lights flash at same time
tried the battery, charge it manually, sounds silly but i had this problem with my 600ss
thanks
Apr 21, 2009 | 1998 Yamaha FZS 600 Fazer
Wont start
Sounds the starter is no good (sometimes they'll work intermittently for a while before they totally **** out). Of course it could just be a starter wiring problem (sending wire).
Mar 12, 2009 | 1997 Ford Expedition
Computers & Internet Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
