Question about Curtis International KLU LT7028 Android Tablet
How do i do a factory reset on KLU LT7028
Cannot recall the passcode to unlock tablet. need to do factory reset
Forgot pass code to open tablet
i dont know of any way to do this without a factory reset. first shut down you tablet. then start it up in recovery(hold power + volume down). and last use volume buttons to scroll down to factory reset
Dec 07, 2014 | Curtis Klu 7-inch Touch Screen Mobile...
How do I install Google play store to my device
Go to the Google web site and do a search for Google Play Store it will take you to here
https://play.google.com/store?hl=en
Nov 01, 2014 | Curtis International Klu LT7028 Tablet -...
Gmailkluunlock
You can reset your tablet to the original setting but it will delete all applications, Videos, Files and any other stuff that you have in the tablets internal storage
You can reset the tablet by using a paper clip to poke the reset hole for 1 minute while the tablet is turned on.
The reset button is located on the side of the tablet, this will reset the system and restart it self and you would notice that all other apps will no longer be there.
The second option is to access the recovery menu on your tablet to reset the system. Again, all applications and any files in the internal storage will be deleted.
To reset:
1. Turn off tablet
2. Press and hold Volume up and power at least 30 seconds to get the menu up,
3. Keep poking the hole to get in to the Wipe data and factory reset then press power to select
4. Once the it process the request, go back to the previous menu and select on restart for the device will power cycle.
Jun 05, 2014 | Curtis International KLU LT7028 Android...
Unlock dot pattern lock android
Normal way for Android is to power down and then hold the power button and the volume Up button.
Way 2 is to hold power, vol up and vol down.
You have to hold until the recovery console appears, so about 20 seconds.
Only a few have a reset button inside a hole.
However, yours is different to all the rest :>)
Just completed this procedure and repeated to confirm: Klu by Curtis 7035-j
1. Make sure tablet is off.
2. Press and hold the "Volume Down" key and `Power` key
3. When "Klu by Curtis" splash screen shows release the power key 4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the `Volume Down` and `Volume Up` and press the `Power` keys to dislplay the BIOS screen.
6. Use the `Volume Up/Down` keys to navigate choices (wipe data/factory reset) and the `Power` key to select the choice.
7. The following screen will ask you to confirm your choice and warn you that this cannot be undone. Repeate step 6 to select your choice.
8. When wiping all data is complete, select `reboot system now` to restart tablet. Done!
Read more: How to perform a factory reset on a Curtis Klu LT7035-J tablet? - How to perform a factory reset on a curtis klu lt7035 j tablet :: Ask Me Fast at http://www.askmefast.com/How_to_perform_a_factory_reset_on_a_Curtis_Klu_LT7035J_tablet-qna6954204.html#q6015781
Curtis Klu 7 inch Touch Screen Google Search
Apr 23, 2017 | Curtis Klu 7-inch Touch Screen Mobile...
Klu LT1041 tablet by Curtis screen went black and now will not turn back on
My son put a 9 point lock on his tablet and does not know the unlock pattern. I have done the reset button so many times and need to get back to the factory settings. Can some one help me figure this out? It has been locked for 4 weeks and im loosing my mind trying to unlock it.
Apr 05, 2013 | Tablets & eReaders
Can not unlock my android curtis klu tablet
For got my password can u send it to me Cody_Corder@yahoo.com temp code to unlock code
Oct 27, 2012 | Curtis International KLU LT7028 Android...
Curtis International KLU LT7028 Android Tablet Logo
88 people viewed this question
Top Curtis International Tablets & eReaders Experts
Coss
David Payne
David Payne
Pierre Legault
Are you a Curtis International Tablet and eReader Expert? Answer questions, earn points and help others
