Question about Injusa Toys
Injusa electric bike
Pluged charger in but there's no light on charger so how do I no if its charging ??
Have lost the battery charger to my grandaughters 6v trimoto samurai bike, currently being sold by Toys'r'Us. Can you please tell me where l can get a replacement?
Hello there
I think you will find the chargers for these trimotos are ' injusa 6 volt chargers'
Well it just so happens there is one for sale here, You may have to change the connector but its only two wires and low voltage.
http://www.ebay.co.uk/itm/Injusa-6v-battery-charger-/311105396806?pt=UK_Toys_Games_Outdoor_Toys_Bikes_Ride_Ons_LE&hash=item486f53a046
Sep 24, 2014 | PRIMOS HUNTING CALLS Primos 6V & 12V...
Hi i have a injusa battery childs car,when i attached the charger plug the green light goes off,but when the charger is not attached to the battery and i flick the switch to on,the green light comes on...
Hi, Check the charger that it is charging.Use a volt/ohm meter to check for power on cable. If battery does not hold a charge. replace battery with new one. Hope that helps.
Nov 27, 2017 | National Kids Mini Cooper Racer Ride On...
Battery charger on green light when battery flat ,it should be on red also when charger plugged into bike, bike works ok when you take charger out bike stops working
If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
Feb 27, 2011 | Electric Bicycle Motor, Bike,electric...
I have the Travel Pal plugged into the charger. The charger has a green light on for electricity being on but there is no light on where it shows it"s charging. And it's not charging.
have yoy checked that the battery is well pluged. meaning possitive with possitive and negative with negative. sometimes grasse is stock on the joints of electricity, so brush them with a metalic brush, that should solve the proble.
Jul 30, 2010 | RTO Mega Motion 3 Wheel Travel Pal Scooter
Battery and Charging
Allow some more time for it to charge as depending on the battery and the rate at which the charger is charging the charging time may vary.Also if the battery was completely empty it may take some time to charge.To summarise allow some more time for the battery to charge, if it makes no difference then take it back to the shop.Hope this helps.
Jun 14, 2010 | Toys
Problems with the INJUSA 12V Jeep - Not working.
Hi Rose,
Yes, batteries can die. But other things can happen too.
If you are comfortable using a voltmeter and the battery is accessible, here are a few things to check. Set it to check DC voltage and:
  • Test the voltage on the battery, is it Low, does it read zero, does it read near 12v?
  • See if it's charging. Do the same test with the charger engaged. It should read 12V. Does it?
  • Does the battery show any signs of leakage?
  • Are the terminals clean?
Get back to me with the results and we can take it from there.
Mike
Dec 08, 2008 | Injusa Two Evasion Ride On Jeep
Toys Logo
14 people viewed this question
Top Injusa Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Injusa Toy Expert? Answer questions, earn points and help others
