Question about Vaultz Locking Mobile Wheelie Chest Letter/Legal, Black
How to reset lock combination?
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
How to reset the entry code to homcom 12"x14"x10"
Most of these Chinese safes have a reset button inside the safe. Open the safe, press reset and enter your new combination. Then check it before closing and locking the safe.
Jul 12, 2014 | Safe International Digital Electronic Safe...
I forgot the combination to my master lock box. What do I need to open the box?
If you do not have the combination, try to contact the manufacturer directly. There may be a serial number on the lock that they can match the combination to.
If that does not work, you will need to contact a locksmith.
Apr 20, 2011 | Master Lock : Locking Combination 5-Key...
I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
Post. (Figure 1)
etc.
original position.
combination.
Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Resetting combination bike lock
Try rotating locking device 180 degrees and hold it down and set combo to 0000, then let up on locking bar. That should clear the old combo. To reset, rotate the device 180 degrees and hold down while inserting your new 4 digit code and then release it.
Jan 31, 2009 | Mongoose Toys
Samsung slide lock
Yes that's possible with every phone just go on settings, security phone settings on automatic key-gard(keyboard) and turn it off. But before you need to know the code for locking and unlocking like in all nokia is green button and *.Not sure for samsung.
Jun 10, 2008 | Samsung SGH-D900 Cellular Phone
Vaultz Locking Mobile Wheelie Chest Letter/Legal, Black Logo
60 people viewed this question
Top Vaultz Office Equipment & Supplies Experts
k24674
Are you a Vaultz Office Equipment and Supply Expert? Answer questions, earn points and help others
